This Truck runs out Fantastic, I've put just about 1300 miles on the motor with the first oil change
@ 500 miles using Shell Rotella. Some work is needed to the steering box as it has a bit of play.
And of course some attention to the body depending on your intentions. All Lights, Turn Signals,
Gauges, Speedometer/Odometer function properly. Two auxiliary fuel tanks are present but are not in use.
Excellent Tires including Spare, Lockable in bed tool box. Borg-Warner T18 transmission & Dana 60 - 3.73 limited
Slip Rear Axel, are in proper working order. No power steering, brakes or A/C. Currently Registered with Clean Title in hand.
Also included is a complete set of Ford repair shop manuals on CD ROM and a Complete Marti Report with
an officially licensed by Ford Data Tag.
Below are the upgrades since April of 2011. All receipts are accounted for.
Re-Manufactured 360 V-8 'Long Block' from Five Star Engine Exchange (Under Warranty)
New Clutch, Pressure Plate and T/O Bearing, Brake & Clutch Pedal Pads, Heater Core, Re Cored
Radiator, Windshield, Rear View Mirror, Door Arm Rests, Door Lock Cylinders, Ignition Switch & Cylinder,
H.D Front Overload Shocks, Defroster Ducts, Heater Control Panel,
Window Washer Reservoir & Pump, Battery, Battery Hold Down & Poly Mat, Dimmer Switch,
Exhaust System, Brake Shoes & Wheel Cylinders, Carpeted Dash Cover, Sun Visors,
Re Padded & Newly Upholstered Bench Seat, Door (2) Weather Stripping to be installed.
A reoccurring left knee issue and space availability are the reasons for the sale.
This would be a great project or first vehicle for someone who appreciates classic trucks !
So I'll kindly ask that only serious buyers inquire.
$ 3,650.00 or best reasonable offer
