mm_0_mm
Kansas Chapter member
02 7.3 starts ok then dies as soon as the accelerator is pressed (manual transmission). starts right back up. if you let it idle for 5-10 minutes, then it will run normally. Started smoking black smoke while accelerating recently also. No tuner currently installed
No CEL, air and fuel filters ok. CPS was replaced during recall. Any ideas where to start? Truck is 400 miles away on the farm, will be heading there for July 4th.
