Home | Gallery | TOTM | New Posts | My Threads / My Replies | Links | Sponsors | Calendar | Arcade | Calculators | Fliers |
Generation 7 1980-1986 F150, F250, F350 |
Thread Tools | Display Modes |
#71
That has. A 1 year free replacement They have a $79.00 with a 2 year replacment. I just bought another group 65 for another truck with a 3 year replacment from Costco. That one was $120. It's 650 cca too Sent from my SM-N960U using Tapatalk
Charlie "A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool." If I keep getting banned from forums, and warned on Facebook, pretty soon I'll learn to behave |
Sponsored Links |
#72
Will these work? Idk if the lengths are correct or not. I need to find the one for starter to engine ground
![]() ![]() Sent from my SM-N975U using Tapatalk |
#73
On RockAuto you should be able to drill down to the specific part by year and model of your truck to confirm that those are correct.
- Russell '77 F100 Flareside "If it jams, force it. If it breaks, it needed replacing anyway." |
#74
#75
Update: i feel sooooo stupid u guys. I was measuring the length of wire to start and ground.. guess what, the dang ground isnt even bolted to the stater anywhere!!!!
Great. Im so dumb its unreal. Does that ground wire go to the bolt of starter to engine? I dont see any other place it would go. I feel so stupid. How in the world did i miss the most simplest piece??? Sent from my SM-N975U using Tapatalk |
#76
Factory generally hooked it up to a point on the block, so the original wire may not make it to the starter as Charlie was indicating to do. Both work, the attachment at the starter just shortens the ground path and reduces the number of potential bad connections,.
My trucks: The workhorse, 86 F250 4x4 6.9 nat aspirated, 3.25 exhaust, custom intake, electric fuel pump, otherwise well used stock... not real pretty but just loves to work! The other heavy hauler, 92 F350 2wd dually crew cab, flatbed/toolboxes, 92 Cummins VE 12V with intercooler, NV4500 manual The beater: 88 F250 4x4, 5.8 5 speed The project ... 1978 F150 4wd shortbed 351 auto ASE certified parts specialist I do most all of my own work so I know who to complain to..Roger |
Thread Tools | |
Display Modes | |
