I might be buying a 1990 F-250 this weekend. it has a 5.8 with im guessing a C6 transmission that is bad, it slips.
Can i bolt a AOD up to the 351?
yes you can...get pics up of the truck.....
I dont really know if it a C6 or not...its just my best guess since it is a F-250.how do you know its a C6? 1990 could have had an E4OD. C6 are pretty tough trannies, might just be low on fluid if it is a C6.
true true.....might just need a filter/fluid change
I would say look at the pan but they are almost identical except the E4OD has a hump toward the ground in the pan...
The C6 will have 1 2 D for the gear selector, and the E4OD will have 1 2 OD or a D in a circle fo the gear selector. IIRC
Yes,but the E4OD Transmission pan is a little bit longer than the C6...
Cody,if you still can't figure it out when you get the truck,take a picture of the tranny pan and post it up.BTW,with my C6,when it gets low on fluid,it doesn't like to go into gear.But when I top it off with fluid,it seems to shift just fine.C6's are finicky little transmissions.
:Edit: You can also tell the transmission by the number of bolts that hold the pan on.
Correct. If the length of the AOD is a lot less than the E4OD, and I think it is, you'll need to have your driveshaft lengthened or buy a new one altogether.Jr said:gonna need a driveshaft made for it....
Okay.gonna need a driveshaft made for it....
Yessir you can. They offered an AOD for that engine-- that's all that matters. Just gotta find one with that bellhousing.
damn right it is the E4OD is a monster in comparison.....
As far as I know, it's a more advanced transmission. That being said, that doesn't speak much about the reliability. I haven't heard more good things about one or the other.Yeah it is. Are the E40D's better that the AOD's?
