Go Back   Ford Truck Fanatics > Engines > 7.3/6.9 IDI
  #1
Old 02-25-2021, 08:47 AM
tanman722001 tanman722001 is offline
Not A Chevy Man
tanman722001 has much to be proud oftanman722001 has much to be proud oftanman722001 has much to be proud oftanman722001 has much to be proud oftanman722001 has much to be proud oftanman722001 has much to be proud oftanman722001 has much to be proud oftanman722001 has much to be proud of
Trans question
Hi everyone. Question is what bell housing to use. I just got a 1975 f350 and i have a 7.3 idi with low miles.truck has a FE motor in it and a granny 4 speed. Other the a 6.9 idi bell housing is there any others that will work? Thanks for any help
1997 F350 Crew Cab DRW. 7.3 turbo diesel with auto
Love working on my truck
Tony
  #2
Old 02-25-2021, 08:29 PM
Fellro's Avatar
Fellro Fellro is offline
Admin
6.9 and 7.3. With some modification to the lineup pin holes, a 460 bell can work. Otherwise, nothing. Next trick is flywheel and clutch. All IDI transmissions used a hydraulic clutch, but the 4 speed variant has a fork that is about the same as a linkage type. Don't remember if the clutch splines would work well on a non-diesel trans or not. The 5 speed version used from the factory a dual mass flywheel which had the springs in it while the 4 speed is more typoical in that it has the springs in the clutch disc.
My trucks:
  #3
Old 02-26-2021, 08:27 AM
Not A Chevy Man
So if i can find and use a 86 model bell housing can i moded the firer wall to mount the res for the hyd clutch. Then see if splines are the same to use about same year clutch. Bc i really dont want to change trans right know. As the truck is a wrecker
Tony
  #4
Old 02-26-2021, 08:32 AM
dustybumpers's Avatar
I'd look for 88 or newer so you can get a zf-5-46. Gives you a nice first gear for take off, and overdrive.
[IMG][/IMG]Charlie
If I keep getting banned from forums, and warned on Facebook, pretty soon I'll learn to behave
  #5
Old 02-26-2021, 09:45 AM
Not A Chevy Man
Later will ZF5 but for right know what to leave 4 speed in the truck. Since truck is a wrecker got to have PTO
Tony
  #6
Old 02-26-2021, 10:58 AM
Zf5-46 has pto covers both sides
[IMG][/IMG]Charlie
  #7
Old 02-27-2021, 11:14 AM
Not A Chevy Man
Yea i have a 4x4 Zf5 . just finding a pto for ZF5 is fun
Tony
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
