  #1
Old 11-29-2019, 07:43 PM
Cattlerest Cattlerest is offline
Cattlerest is on a distinguished road
Can you test the VSS signal at the PCM connector?
IM NEW HERE THANKS FOR THE ADD GUYS! IM Looking for PCM connector pinout 1995 ford f150 5.8 E4OD TRANS appreciate any help. Trying to see if theres a way to test the VSS signal at the pcm pretty sure it goes through the PSOM before going to the PCM. Just wondering if testing the negative and positive PSOM wires would verify that the VSS signal was getting to the PCM Thanks in advance Guys
  #2
Old 11-30-2019, 04:33 AM
heavydoc's Avatar
heavydoc heavydoc is offline
heavydoc is a splendid one to beholdheavydoc is a splendid one to beholdheavydoc is a splendid one to beholdheavydoc is a splendid one to beholdheavydoc is a splendid one to beholdheavydoc is a splendid one to beholdheavydoc is a splendid one to behold
Welcome to FTF from WNC.
You could ohm the vss an then hook it back up the ohm the wire to compare the readings.
96 F-350 RCLB DRW 2WD
01 Excursion Limited 4WD
02 F-350 CCLB DRW 4WD
20 Kenworth T270
"DOC"
  #3
Old 11-30-2019, 04:14 PM
Got it Thanks!
  #4
Old 12-11-2019, 06:08 AM
Abdallo Abdallo is offline
Abdallo is on a distinguished road
Is there any danger of frying any wires when doing this?
  #5
Old 12-11-2019, 06:56 AM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
Should fry any thing as long as you probe the correct pins.
Click for weather forecast
________________
Randy
  #6
Old 12-11-2019, 04:09 PM
heavydoc's Avatar
No danger at all testing the wires or sensor
20 Kenworth T270
"DOC"
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
