Go Back   Ford Truck Fanatics > F-Series > Generation 1
Generation 1 1948-1952 F1 thru F8
  #1
Old 01-17-2019, 05:48 AM
Bloegwta Bloegwta is offline
Bloegwta is on a distinguished road
1950 trans options
I am overhauling a 1950 F1 for a friend whose grandfather bought the truck new. Engine is no problem, but the 59T 7006 DGD N1 transmission is. Four speed with tractor low, all straight cut gears, and no synchros. It's got a bad cluster gear, reverse idler, and 3rd/4th gears. Useable but very badly worn. That description fits me after trying to find parts for this trans. Any help there? If not, what can I use for a drop in swap with tractor low and maybe some synchronizers and parts availability? Thanks! Steve BTW, how may one owner 1950 F1's out there?
  #2
Old 01-18-2019, 12:11 AM
truckdog62563's Avatar
truckdog62563 truckdog62563 is offline
truckdog62563 is a jewel in the roughtruckdog62563 is a jewel in the roughtruckdog62563 is a jewel in the roughtruckdog62563 is a jewel in the rough
Van Pelt will have your parts. Stu
http://www.vanpeltsales.com/FH_web/t...prices-pg1.htm
Stu McMillan
1952 F-3 Marmon-Herrington
  #3
Old 01-19-2019, 07:21 AM
Talked to van Pelt and they don't have any new or even good used gears for this trans. They know what it is and are familiar with it, but no parts.
  #4
Old 01-19-2019, 07:29 AM
If this helps, I need BB7101 3rd/4th gear, BB7113A cluster gear, and BB7141 reverse idler. I would really like to know what model and year might use a version of this trans that would drop in and have some synchros and parts availability. I would overhaul that and put it in. Thanks everyone for your help!
  #5
Old 01-19-2019, 08:46 AM
Hmmm, I’m surprised Van Pelt doesn’t have the parts. Next idea is to check with Chuck Mantiglia at Chuck’s Trucks in CT. IIRC he told me he has converted one of his own half ton trucks to the 3HD transmission that is synchro on 2nd and 3rd gear. Stu
http://www.chuckstrucksllc.com/startframe.htm
Stu McMillan
  #6
Old 02-20-2019, 07:14 AM
mtflat mtflat is offline
Flatheads Forever
mtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond repute
Where are you?
I have a 59T 4 spd taking up space on my shop floor that was given to me. I don't know the condition, but I'd give it away to someone who needed it. However, I'm in nw Montana... thus my first question.
The one Stu mentioned is the T87D - 3 spd HD. I have one in my 48 F1 and they are indestructible.
...Tim
  #7
Old 03-05-2019, 05:05 AM
59T
Tim, sorry for not getting back to you right away, the combination of this ugly winter and getting the engine assembled pulled me off the trans. If you still have this trans, I'd sure like to know what the innards look like before I send you some money have it shipped down here. I travel for a living, but NW Montana is not a hot spot. Can we work something out? Thanks! You can text me at 402-630-2399
Steve
  #8
Old 03-05-2019, 09:57 PM
49fordv8f4's Avatar
49fordv8f4 49fordv8f4 is offline
49fordv8f4 is on a distinguished road
Steve, If your travels bring you to north central Arkansas, I have a couple of T9 4 speeds as well.
Mark
Salvation is free, but discipleship will cost you your life. Deitrich Bonhoeffer
Acts 4:12; Romans 8:29; Ephesians 2:8-10
  #9
Old 03-12-2019, 07:33 PM
Flatheads Forever
I don't check this every day either - when I posted the other note, I had just ret'd from Ohio and drove the length of Nebraska on I70. Went that far south to avoid the snow storm and as luck would have it I drove right thru the middle of it in IA and NE. I'll text you from 406 two six one 6665
...Tim
  #10
Old 03-18-2019, 09:56 PM
BKW's Avatar
BKW BKW is offline
Ford Parts Guru
BKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond repute
Quote:
Originally Posted by Bloegwta View Post
I am overhauling a 1950 F1 for a friend whose grandfather bought the truck new. Engine is no problem, but the 59T 7006 transmission is.
This is not the trans type, it's the part number marked on and for the case.
Trans is the Borg-Warner T-9.
BB-7101 .. 3rd/4th Gear / Obsolete
NOS PARTS LTD in Waxahachie TX has 1 = 962-937-2201.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 30 = 800-476-9653.
BB-7113-A (replaced BB-7113) .. Cluster Gear / Obsolete
No Ford dealer or obsolete parts vendor has any.
BB-7113 =
NOS PARTS SOURCE has 1.
KLIMESH MOTOR SALES in Calmar IA has 1 = 563-562-3241.
BB-7141 .. Reverse Idler Gear / Obsolete
CARPENTER NOS OBSOLETE PARTS has 14.
Pic: T-9 TRANS parts list #5 showing these 3 part numbers.
Bill / Retired Ford Parts Manager / Part Number Research: 1928/2001 FoMoCo vehicles.
2017 Fusion SE
Tags
1950, 4 speed transmission, f1 transmission
