Go Back   Ford Truck Fanatics > Engines > 351M, 400
  #1
Old 11-21-2014, 10:02 PM
fatherdoug's Avatar
This doesn't look good!
I have a thermostat that is sticking open. (Robert Shaw 333-192). Temps only get up to 180 when engine is warm. I thought no problem - order another one. Much to my amazement, I cannot locate a thermostat for a 400 engine.
Flowkooler no longer lists a thermostat for the 400. Tried a lot of other sites, and they all say they are no longer available and will not be reordered. WTH!
I did find a thermostat on a Mustang website for a 351C for (gulp) $55. Is the "C" thermostat interchangeable with the "M" thermostat?
If I remember the Motorcraft RT-139 is the proper replacement? I am having a hard time finding one of those, also.
Does someone have a source for these that they would be willing to share?
'78 F-150 Lariat
Quote:
Quote:
  #2
Old 11-21-2014, 10:06 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
This could suck!!...time to do some looking, thanks for the heads up!
Edit...I'm pretty sure the 351C is the same....flame suit on if I'm wrong!
Quote:
Quote:
Quote:
  #3
Old 11-21-2014, 10:10 PM
fatherdoug's Avatar
It sucks cold air already.
'78 F-150 Lariat
  #4
Old 11-21-2014, 10:43 PM
DNFXDLI's Avatar
Admin
Better than hairy donkey nads
  #5
Old 11-22-2014, 01:03 AM
kiwi f150's Avatar
kiwi f150 kiwi f150 is offline
kiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond repute
Here you go Doug - this is a 180 deg one but summit have 160 and 195 deg ones too depending on your needs.
http://www.summitracing.com/int/part...view/make/ford
Cheers Mark
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rapidly promoted by mainstream media, which holds forth the proposition that it is entirely possible to pick up a piece of sh*t by the clean end."
  #6
Old 11-22-2014, 01:05 AM
kiwi f150's Avatar
Here's another one for the 400
http://www.autopartswarehouse.com/sh...ord/m-400.html
Cheers Mark
  #7
Old 11-22-2014, 01:08 AM
fatherdoug's Avatar
Thank you, Mark! I also located a NAPA THM 297 that has the flange on the bottom for the M engine internal bypass. I'm not sure about chain store quality, though.
http://www.napaonline.com/Catalog/Ca...297_0293194651
'78 F-150 Lariat
  #8
Old 11-22-2014, 01:11 AM
fatherdoug's Avatar
Not sure if this one would work? There is no picture of the bottom of the thermostat.
Autparts Warehouse also lists the thermostat for the Windsor engine......
'78 F-150 Lariat
  #9
Old 11-22-2014, 01:17 AM
fatherdoug's Avatar
Quote:
Or hairy sheeps nads. Eric can run with this one..............
'78 F-150 Lariat
  #10
Old 11-22-2014, 01:22 AM
kiwi f150's Avatar
Yep i just went back and did some more looking on the summit site - if you go looking for the 385/cleveland series specifically it brings up this one and in the comments on the sidebar there is a chap who say's it fits and it works but it's not quite right.
http://www.summitracing.com/int/part...l/f-250-pickup
Cheers Mark
