Go Back   Ford Truck Fanatics > Superduties & Other Trucks > Superduty Gen.1
Superduty Gen.1 1999-2007 F250, F350, F450, F550
  #1
Old 08-31-2012, 04:01 AM
Scot Bailey Scot Bailey is offline
Scot Bailey is on a distinguished road
Superduty Bed Supports
Does anyone know if the bed supports are reproduced anywhere? I am the original owner of a 2001 F350 7.3 with 70K on the clock that has non existent supports on a couple of the ends. It makes me sick! I was thinking of using square tube stock, but I'm not sure yet.
Thanks, Scot
  #2
Old 08-31-2012, 08:03 AM
Blue Goose's Avatar
Blue Goose Blue Goose is offline
Blue Goose has a reputation beyond reputeBlue Goose has a reputation beyond reputeBlue Goose has a reputation beyond reputeBlue Goose has a reputation beyond reputeBlue Goose has a reputation beyond reputeBlue Goose has a reputation beyond reputeBlue Goose has a reputation beyond reputeBlue Goose has a reputation beyond reputeBlue Goose has a reputation beyond reputeBlue Goose has a reputation beyond reputeBlue Goose has a reputation beyond repute
Here ya go, Scot.... It works better if you plug in the VIN into the search window (long bed/short bed etc)
http://www.fordparts.com/
Brad
  #3
Old 08-31-2012, 12:56 PM
Thanks Brad. I didn't even think to check with FORD
Scot
  #4
Old 08-31-2012, 01:05 PM
Blue Goose's Avatar
Scot, there are some 'ford parts guys' online that sell Ford parts at a pretty good discount, so if you poke around on the net you might find some better pricing.....Also, ya might just check with your local dealer. Another thing you might try is finding some aftermarket. There are aftermarket body panel companies (I don't know the names) that might produce these as well...
Brad
  #5
Old 09-01-2012, 03:26 PM
You know Brad, after taking a better look at the 2 supports that you highlighted, I realized those are not the ones I need! The rusted supports I have are the ones that are part of the bed floor ( 00038 in the parts breakdown ) and it seems they are not available from Ford separate from the looks of the diagram.
  #6
Old 09-01-2012, 04:03 PM
Blue Goose's Avatar
I believe what they're showing is that there are two distinct cross members that makeup however many there are (depending on the bed length). They are all installed by spot welding to the floor pan. I can't imagine why they would offer some and not the others...
Brad
  #7
Old 09-16-2012, 07:17 AM
Here is an update on the project. The three center supports are shot.
The bed is good...rusty supports make it look worse than it is. This one was nasty
POR15 on the surface rust
I made new supports from 1/8" box
Bed is done
  #8
Old 09-16-2012, 07:29 AM
Now on to prettying up the frame and replacing brake lines that look nasty as well as the muffler that is starting to go on the bottom seam so I am replacing it with a delete pipe while the bed is off.
  #9
Old 09-16-2012, 08:15 AM
Lost's Avatar
Lost Lost is offline
PA Chapter leader
Lost is a glorious beacon of lightLost is a glorious beacon of lightLost is a glorious beacon of lightLost is a glorious beacon of lightLost is a glorious beacon of light
About normal condition for around here . Surprised wheel arches and cab corners r not gone
If you can't find a part used u r not looking hard enough..
94 F150 302 MAf E4od sc long bed 4x4 3:55 LS rears
9MM Ford racing wires MSD cap & rotor and Blaster coil coil . 14-15 MPG Thanks
95 F150 300-6 auto 4x4 8 ft bed barney mobile (yep its purple) . 1 ton front coil and f260 rear leaf suspension Its the plow/firewood truck
  #10
Old 08-20-2014, 11:49 AM
mike goode mike goode is offline
mike goode
mike goode is on a distinguished road
bed supports
hi/new to forum and noticed you were going to replace your bed supports on your truck.Was wondering if you knew the sizes of the rails as mine are beyond getting an accurate measurement /I was going to try 1/8th tubing but they all appear to be a diff height/I have an 2001 f350 superduty with 8ft bed 7.3 diesel/any help would be greatfully appreciated
