Go Back   Ford Truck Fanatics > Engines > 6.0 Powerstroke
  #1
Old 08-06-2012, 10:49 PM
Beachbumcook's Avatar
Beachbumcook Beachbumcook is offline
Beachbumcook is just really niceBeachbumcook is just really niceBeachbumcook is just really niceBeachbumcook is just really niceBeachbumcook is just really nice
215,000 Miles And I had To Spend Some Money!!!
With 215,000 miles on my 2003, 6.0L Excursion, I had to spend some money on replacing the following:
1) New turbo
2) New driver's side turbo inlet pipe.
3) Install exhaust manifold gaskets and new bolts
My turbo stuck in the open position, which resulted in poor performance and horrible low end power. As well, the mechanic's computer showed that I had low pressure and I had some "codes" that had been generated.
The turbo inlet pipe and exhaust manifold gaskets were leaking and made for a smelly cab when stopped at a light.
All was fixed by my local Ford dealer and trusted diesel tech in 1-1/2 days.
The next week, my truck would not start at 12:30am after arriving back into the Kansas City airport... had it jump started... and all was well. Went to dealer and had batteries tested due to being only 4 years old.... and what did they find out... that I had 2 bad batteries (at least 1 bad cell in each of the 2 batteries). No warning... nothing... just would not start after sitting at airport for 2 days!!!
Now... all is well... I have power, no exhaust smell in the cab and it starts without fail!!!
BTW, my last Blackstone oil analysis report showed that my motor is operating 100% perfect and has always been... so I am feeling really good about it with 215,000 miles on the odometer.
03 Excursion 6.0L PSD
Magnefine P/S Fluid Filter
Rotella Syn - 5W-40 Oil
Dieselsite Coolant Filter
Bilstein Shocks
Fumoto Oil Drain Valve
BriteBox Headlight Module
Marinco AC Block Heater Plug
24" Wiper Blades
Window Screen - Radiator Bug Shield
Pioneer Airware XM Radio
Powerservice Fuel Additive - Every Tank
  #2
Old 08-07-2012, 08:13 AM
O'Rattlecan's Avatar
O'Rattlecan O'Rattlecan is offline
O'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond repute
Was the dying turbo perhaps the cause of the exhaust smell?
edit: oh, I missed that part in your post. Glad everything is working good!
  #3
Old 08-07-2012, 05:45 PM
Smell in can was due to cracked turbo inlet pipe (flex joint) and to a lesser degree the leaking exhaust manifold gaskets. The factory does not use gaskets.... so they leak over time.... the fix is to use gaskets.
Bilstein Shocks
24" Wiper Blades
  #4
Old 02-10-2013, 05:08 PM
Update - All Is Well At 226,000 Miles...
Update...
Truck now at 226,000 miles as of 2/10/13 and all is well.
Bilstein Shocks
24" Wiper Blades
  #5
Old 02-10-2013, 05:24 PM
m78's Avatar
m78 m78 is offline
m78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond repute
I doubt I've driven that many miles since I started driving.
Mark
  #6
Old 02-13-2013, 07:19 AM
Blue Goose's Avatar
Blue Goose Blue Goose is offline
Blue Goose has a reputation beyond reputeBlue Goose has a reputation beyond reputeBlue Goose has a reputation beyond reputeBlue Goose has a reputation beyond reputeBlue Goose has a reputation beyond reputeBlue Goose has a reputation beyond reputeBlue Goose has a reputation beyond reputeBlue Goose has a reputation beyond reputeBlue Goose has a reputation beyond reputeBlue Goose has a reputation beyond reputeBlue Goose has a reputation beyond repute
Beach, you just keep on keepin' on shining the positive light on the much maligned 6.0.....There has been so much bad said about them and not enough of guys like you reporting on the good. Your 216k miles renews my faith and dwarfs my 84.5k. BTW, other than the FICM going south, mine's been flawless....With diesel prices being what they are I don't drive it much anymore, but when I do, it brings back the smile....
Brad
  #7
Old 02-14-2013, 12:28 AM
satcom40's Avatar
satcom40 satcom40 is offline
satcom40 is on a distinguished road
I'm at 160 K and running good. Just had to replace the ball joints. lastest oil report came back good. It's my daily drive in the winter. I just love it. But $80 a week for fuel is a bummer.
Go 6.0
04 F-250 4x4 EC XLT
6.0 L Diesel Engine
46 Gal Tranfer flow tank
Pre-Post Luber
Remote Start
Coolant Filter
Oil guard bypass filter
Boost/Pyro gauge
Scan Gauge
Inlet elbow
  #8
Old 02-16-2013, 04:14 PM
Bloodhound's Avatar
Bloodhound Bloodhound is offline
Oilfield Trash
Bloodhound is a splendid one to beholdBloodhound is a splendid one to beholdBloodhound is a splendid one to beholdBloodhound is a splendid one to beholdBloodhound is a splendid one to beholdBloodhound is a splendid one to beholdBloodhound is a splendid one to behold
My Ex had 175,000 trouble free miles when I traded her in last month. All it had was routine maintaince, Batteries, Alternator, FICM, one sensor, and in the shop for an oil leak.
I hated to see it go but I needed a truck. The ex wouldnt pull a goosneck or 5th wheel.
Robert
13 Explorer XLT w/Ecoboost
09 F350 Lariat 6.4 4x4
79 Bronco, 39.5 tsl's, 460 auto
  #9
Old 06-26-2013, 07:41 PM
I now have 242,000 miles and all is well.
Bought a Harley Electra-Glide Ultra Classic motorcycle, so driving the bike more than the car right now.
Bilstein Shocks
24" Wiper Blades
  #10
Old 06-26-2013, 07:47 PM
Blue Goose's Avatar
Quote:
Holy cats!!! I'm at 85,300.....and all is well...
Brad
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
