Home Forum Gallery TOTM Links Sponsors Calendar Arcade Calculators
Go Back   Ford Truck Fanatics > General Maintenance, Performance, and Tech. Info > Certified Ford Tech Help Forum
Register FAQ Members List Search Today's Posts Mark Forums Read My Threads / My Replies Fliers
Find us on Facebook
Certified Ford Tech Help Forum Got a mechanical problem or question about your Ford Truck? Post it here for answers.
Welcome to the Ford Truck Fanatics forums.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact contact us.
Login for fewer ads.
  #1
Old 05-24-2011, 03:18 PM
Fordzilla80's Avatar
Fordzilla80 Fordzilla80 is offline
Ranger Lariat
Fordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond reputeFordzilla80 has a reputation beyond repute
Ranger 3.0, poor idle and acceleration
Recently for the last few weeks i've had a big problem with my 03 Ranger. Whenever I start the truck up in the morning, it runs great. But as I drive, about 15-20 minutes into driving the truck will develop a jumpy idle at stops. It'll fluctuate between 500 and 1,000, and occasionally it dips below 500 and completely stalls out. When I go to accelerate, the truck will start going, then it just completely bogs down for a second or two, then it comes out of the bog and returns to normal. The warmer the truck gets the worse this gets until eventually it happens at every single stop. It just recently threw two codes, one for the IAC and one for the IAT. But I previously unplugged the IAC and MAF to test them out while the truck was running, so I think that's where those two codes came from.
Things i've checked:
-TPS
-IAC
-MAF
-Cleaned the Throttle Body and linkage
One thing I noticed is that I may have a vacuum leak somewhere around the intake, towards the back of the motor. It doesn't seem like the intake though, as it's not significant. It's just a constant sssssss that seems muffled, like it's under the intake. Is it possible that one of my injector seals is bad? If it helps any, the truck only has 48,000 miles on it. I greatly appreciate any suggestions.
Shaun
1980 Ford F150 Ranger Lariat
2003 Ford Ranger Edge
  #2
Old 05-24-2011, 07:55 PM
blacksnapon's Avatar
blacksnapon blacksnapon is offline
blacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond repute
TSB
05-22-12 BUCK/JERK AND MISS DURING DRIVE CYCLE ABOVE 3000 RPM - NO DTC - 3.0L 2V GAS AND FFV ENGINE
Publication Date: October 25, 2005
FORD: 2000-2003 Taurus, Ranger
MERCURY: 2000-2003 Sable
ISSUE:
Some 2000-2003 Taurus, Sable, Ranger vehicles equipped with a 3.0L 2-valve gas or FFV engine may exhibit a buck/jerk/miss during drive cycles above 3000 RPM with no diagnostic trouble codes (DTC's). A possible cause is the camshaft synchronizer assembly. Since the camshaft position (CMP) fault monitor is not active above 2500 RPM, no diagnostic trouble code (P0340) is set during the drive concern, thus making it difficult to diagnose the root cause component.
ACTION:
Use an NGS to identify whether or not the synchronizer is the causal component. Refer to the following Service Procedure.
SERVICE PROCEDURE
Select PID database.
Select "Fuel Priority" PID database.
Select KS1 and RPM PID's.
Capture data during drive symptom.
Using graph mode, display KS1 and RPM.
Look for knock errors which can be identified by rapidly rising peaks which correlate with drops in RPM (Figure 1).
If the synchronizer assembly needs to be replaced, follow the appropriate model year Workshop Manual, Section 303-14, Electronic Engine Controls, Camshaft Synchronizer - 3.0L (2V) Removal and Installation procedure.
ase master tech--fmc senior master tech
  #3
Old 05-25-2011, 05:14 AM
d-kuzmen's Avatar
d-kuzmen d-kuzmen is offline
Master Ford Tech
d-kuzmen is a splendid one to beholdd-kuzmen is a splendid one to beholdd-kuzmen is a splendid one to beholdd-kuzmen is a splendid one to beholdd-kuzmen is a splendid one to beholdd-kuzmen is a splendid one to beholdd-kuzmen is a splendid one to beholdd-kuzmen is a splendid one to behold
You can use water to check for a vaccume leak. Pour some water around the intake and injectors, if you hear it sucking the water in you will know where you have to look. What happened when you unpluged the iac did it stall or continue to have rolling idle?
Dave
Ford Senior Master
Master ASE Certified
Diesel Certified
Owner/Operator of
Dave's Garage LLC
Canterbury,CT
860-546-6441
Installer Of Bullet Proof Diesel Products
Click for Jewett City, Connecticut Forecast
  #4
Old 05-25-2011, 07:47 AM
Ranger Lariat
Thanks for the replies!
Blacksnapon, I am aware of the problems with the Cam sync on these 3.0 and 4.0 OHV Rangers, however I do not believe this is my issue. My truck doesn't have any trouble above 3,000 rpms, in fact that's when it runs best. My problem is below 1,000 rpms. Also, it isn't really a buck/miss/jerk, it's more of a bogging down, and there are no discernible chirping sounds coming from the area of the cam sync.
D-kuzmen, I have unplugged the IAC, and the idle momentarily drops down, but then it comes back up and seems to regulate itself. I did not pay attention to see if it still gave me the same issue, will go and try that in a few minutes. As for the vacuum leaks, water is a good idea. Without the upper intake plenum removed I have pretty much no access to the bank 2 injectors.
Shaun
  #5
Old 05-25-2011, 08:52 AM
Ranger Lariat
Update: I went out and unplugged the IAC, and the idle dropped down to around 500 rpms. However it did not fluctuate. I decided to check something else, and then I decided to try and unplug the IAC again. Now when I unplug it nothing happens?
Shaun
  #6
Old 05-25-2011, 12:10 PM
Yeah, looking for that vacuum leak would be a priority. The IAC motor is essentially just regulating airflow. If theres a leak, the IAC cant regulate it that much. I usually use a can of carb cleaner with the straw. The straw will allow you to pinpoint the leak closer.
  #7
Old 05-25-2011, 12:22 PM
Ranger Lariat
Quote:
Thanks man! I'm waiting for it to cool down outside, but as soon as it does i'm gonna see what I can find. I hit the injectors with a little water, and no discernible difference in idle. I'm gonna try again, but as BlueGoose suggested to me a length of hose and your ear will get me a better indication of the exact location of the sssss sound. I'm gonna try the upper intake plenum seal, the lower intake seal, the pvc elbow, and any other vacuum source on the back of the motor. I'll update what I find. I'll update with what I find.
Shaun
  #8
Old 06-06-2011, 07:16 PM
Ranger Lariat
Been narrowing things down. I don't know what i'm hearing but it isn't a vacuum leak. Truck is pulling 18" hg of vacuum at idle. Haven't yet checked it under load, but I wouldn't imagine it would make any difference. The water test came up with nothing at all. Neither did Carb Cleaner. I replaced the deteriorated EVAP purge valve hose that connects to the upper intake plenum, but that didn't do much of anything. I tested the new TPS, and couldn't get an accurate reading from it after multiple tries. Since it was still new and had a 2 year warranty, decided to take it back for a replacement. I put the new TPS on, wiped the KAM, went back through the idle re-learn strategy, and it's still doing it. One thing I did notice is that if I just gradually apply the throttle, then it's fine and doesn't hesitate or bog down. It's just when medium to heavy throttle is applied. So taking that into account, it kind of sounds like a fuel starvation problem to me, like the computer can't pull fuel fast enough to the injectors. It hasn't had a fuel filter put on it to my knowledge since 2005 at 25,000 miles, so i'm gonna pull that off and blow through it to see what kind of resistance I get just to see if it's clogged up. If it is i'll replace it. If not, i'll be doing a fuel pressure test to see what i'm reading for that.
Shaun
  #9
Old 06-07-2011, 05:29 AM
d-kuzmen's Avatar
Master Ford Tech
If the fuel pressure is ok I would recomend unplugging the MAF sensor and driving it to see if it's any better. A faulty MAF can give you the boging down if it's unable to determin the amount of air entering the engine, or if the baro sensor (part of the maf) thinks your up in the mountains it will do screwy things.
Dave
Ford Senior Master
Diesel Certified
Owner/Operator of
Dave's Garage LLC
Canterbury,CT
860-546-6441
  #10
Old 06-11-2011, 07:49 PM
Ranger Lariat
Quote:
I haven't gotten around to the fuel pressure test, but i'll definitely try unpluggin the MAF on my way to work to see if it does any better. Thanks for the suggestion.
Shaun
vB code is On
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
