Push Button Start How To
lil_dq
Let 'er eat boys!
6,933
266
Union, MO
ATTENTION!!!!
DOING THIS MODIFICATION WILL REMOVE ALL ANTI-THEFT FEATURES OFF OF YOUR TRUCK AND IN DOING THIS MODIFICATION THIS WEBSITE AND OWNERS OF SAID WEBISTE ARE NOT LIABLE FOR THE THEFT OF YOUR VEHICLE!!!!
ANY POSTS NOT RELATED TO THIS MODIFICATION WILL BE DELETED BY ME. I WANT TO KEEP THIS EASY TO FOLLOW AS THIS WILL BE LINKED ON OTHER SITES AS WELL.
OK now that all the legal stuff is out of the way.... I am starting this thread to get the ball rolling on my push button start for the truck. There are a few things that will have to be done to it to be able to do this mod.
1. Your PATS system will have to be turned off!
2. The Wheel lock will have to be modified to do this mod.
3. There will be NO key used AFTER this mod. (If you would like to still use a key, this is NOT the mod you are looking for)
4. Your truck will be able to start at the push of a button, that means that anyone who can push a button can drive your truck. Keep that in mind if you are parking it anywhere you don't feel safe doing so.
Also keep in mind my truck is my toy and NOT a daily driver. Therefor I feel OK doing this mod.
Truckin4life
Texas Chapter Leader
9,037
San Antonio, Texas
Is it really straight forward, push a button, or is there "activiation switches"
Could be intresting to hop in and push a button and all systems are nominal.
Alas, plan on unpushing said button?
lil_dq
Let 'er eat boys!
6,933
266
Union, MO
This is the switch kit I am using...Obviously I am going to remove them from the panel and relocate to an area I see fit in the truck...
Truckin4life
9,037
San Antonio, Texas
Niftyness. So basically everything will be run to the ignition switch?
Im curious on wiring of this.
Being EFI im seeing a maze of wires and relays...
Truckin4life
9,037
San Antonio, Texas
Also is there ANY plan for ANY kind of theft detterent?
Even a simple battery disconnect switch or a not very obvious switch to provide power to the ignition button?
lil_dq
Let 'er eat boys!
6,933
266
Union, MO
I have been kicking around a battery disconnect, but since this is NOT a daily driver, and I will still have my keyless entry I am not too terribly concerned.
Truckin4life
9,037
San Antonio, Texas
Thats what i was thinking, Randy.
Not a true disconnect, other wise your computer will have to relearn everytime you take the truck out.
Just a simple toggle to break the power in the hot side of the actual start button...
Wont take much of anything to wire it in and its just a bit more insurance.
lil_dq
Let 'er eat boys!
6,933
266
Union, MO
Step one:
Play on the computer for about 6 hours trying to figure out how you are going to wire this thing in...Check!
Here is a drawing of what to do, and when I get it torn apart I will take some real life pics of what ends up happening...
Truckin4life
9,037
San Antonio, Texas
As before double check amp draw on those wires your runnin through the switches, compare it to the rated capacity of the switches you plan on using.
Im an advocate for using relays for safety purposes...
lil_dq
Let 'er eat boys!
6,933
266
Union, MO
Yeah I am checking on that now. The switch kit comes in either 60a or 25a. I think I am going to go the 60a way...
4,038
135
Trinity Tx
I know you said your not worried about it but, I gotta agree with Don and Randy about the kill switch..
Just a little extra insurance is all...
lil_dq
Let 'er eat boys!
6,933
266
Union, MO
I found a spot for the pushbutton. It will be hidden a little. I will take pics as I go.
Truckin4life
9,037
San Antonio, Texas
Use your cigarette lighter as your pushbutton.
Would be pretty sweet and would be stealth like a freakin ninja!
If you want im sure i can come up with something for ya.
lil_dq
Let 'er eat boys!
6,933
266
Union, MO
That is exactly where I am putting it. LOL
My Acura is push button start
A lot of guys are using the S2000 button, but some have talked of the keyless type styles like yours.
Truckin4life
9,037
San Antonio, Texas
Wouldnt be hard to do, get a little crafty with mounting it securely and your good to go. I thought it would be cool to turn one into a bass knob, then i saw Steve Meade did it a build he did. Totally took that idea from me, and claimed it for his own.
lil_dq
Let 'er eat boys!
6,933
266
Union, MO
LOL I am going to work on it today some more. Got to run to the parts store to get some stuff.
lil_dq
Let 'er eat boys!
6,933
266
Union, MO
Parts store had to order some of the items I needed. Should be in tomorrow. I will load pics tomorrow as they are on my phone and I have my computer hook up at work for my phone.
