Go Back   Ford Truck Fanatics > F-Series > Generation 7
Generation 7 1980-1986 F150, F250, F350
  #1
Old 11-07-2010, 08:34 PM
andbluesman andbluesman is offline
andbluesman is on a distinguished road
clutch equalizer bushings 81 F-100 4.9 4speed od
I need some help. My reserch so far has been a little confusing. The drawings on sites I'm finding for this application so far do not look like what I have. The bushings on the block mount stud and washers and clip look right, but on the frame mount side it is a larger size ball, and there really is not anything left to compare it to. This side also has a kind of a horse shoe shaped clip in it. Should this be a two piece busing and if so where do you purchase them? also clutch equalizer bar is shaped a little different in the drawings than I have and mine has clevises made on both ends, of the equalizer bar, one going to the clutch pedal rod and the other going to the clutch adjustment rod.
  #2
Old 11-16-2010, 05:56 PM
BKW's Avatar
BKW BKW is offline
Ford Parts Guru
BKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant future
Quote:
2) C1AA7543B (replaced C1AA7543A) .. Equalizer Bar Pivot Bushing / 5/8" I.D. / 1" O.D. / 1/2" thick.
Fits all V8 & I-6: 1965/82 F100/350 / 1966/82 Bronco / 1969/74 Econoline.
If someone changed one of the pivots, this is the reason why one size pivot bushing is larger than the other. A PO couldn't find the correct part, so substituted something else.
My guess is, the frame mounted pivot is the culprit, since the I.D. of the engine pivot is the same from 1965/82, but 1980/82 is a different part from 1965/79.
The clips fit on the end of the pivots to retain the bushings, there's also a felt washer on either side.
What city/state are you located in? I'll tell you where the parts can be found.
Bill / Retired Ford Parts Manager / Part Number Research: 1928/2001 FoMoCo vehicles.
2017 Fusion SE
  #3
Old 11-18-2010, 08:30 PM
I am located in Anderson, Indiana. The frame mount pivot is a larger ball shape, most of the bushing is gone but I believe it might be a two piece bushing.
  #4
Old 11-19-2010, 02:13 AM
BKW's Avatar
BKW BKW is offline
Ford Parts Guru
There is no such thing as a two piece bushing after 1964, and those were bronze.
All 1965/82 F100/350's have a one piece nylon bushing. Two are required, one on the engine pivot, one on the frame pivot.
I listed the specs in my other post, compare with your bushings.
2017 Fusion SE
  #5
Old 11-20-2010, 03:56 PM
The Problem I Have Is The Engine Side Pivot Is Much Smaller And Not A Ball Shape And Is Phisically Not Able To Fit Over Frame Mount Pivot, Also Frame Mount Side Has A Funny Shaped Clip That Has The 2 Ends Going Thru 2 Small Holes In The Equalizer Bar To Keep It, Locked Behind Larger Ball Pivot On Frame Side Instead Of C Type Clips I Have Seen In Catalogs But That Would Work On My Engine Side Pivot.
  #6
Old 11-20-2010, 04:17 PM
Can you tell me where I could find the frame mount pivot and frame bracket to replace it and would accept these bushings on both pivots. If I could post pictures on here of my parts it might make more sense as i have them all removed at present. I also have really bad wear on pedal assembly arm bracket that hooks to clutch pedal rod which is also almost wore thru and other end is is a whole instead of clevis and is wore I do not know but maybe requires buhings. My equalizer bar is also not shaped like the flat style bar LMC catalog it is more of a gradule U shape as I have seen in some catalog diagrams that said typical style for 80-82 Ford.
