| Generations 8-9 1987-1996 F150 + 1987-1997 F250, F350 |
Welcome to the Ford Truck Fanatics forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1
how to remove headlight assembly?
I need to remove the turn signal/marker light/ headlight bezel and lenses to replace broken ones and I need to find out the correct way to remove. This is on a '94 F-150.
I'll be going to a picka part junkyard to get new assembly, and was wondering if there's only a few screws to remove or if I gotta get in behind the assembly from inside engine compartment to remove any screws. The bezel and lenses are already busted and stripped from my truck now, the actual headlight lens is still intact. Jim |
| Sponsored Links |
#2
Unfortunately this is not an 'easy' task if you haven't done it before. It's not impossible or even that hard, but the way it was installed is like nothing I had seen before.
From inside the engine compartment if memory serves there are 3 nuts on studs that are physically attached to the light. You have to remove those 3 nuts. When you get those off the bezel and amber bottom light and the corner light will come off but the main headlight will still be in place, but it's much more self-explanitory once you get that cover off. Ryan
#3
subscribing. will be doin this soon to swap to euro lights.
#4
Ryan, Thanks alot. That's just what I was wondering. Thanks to a run in with a chainlink fence my bezel and amber lens and side marker lens got destroyed but not enough to clearly show me how to remove the whole assembly and reinstall.
I'll be going to a junkyard next weekend and wanted to know exactly how to remove the assembly. Thank you for the help. Jim |
#5
If you can find an exploded diagram, it'll help a lot.
I've only torn one apart, but I don't know if I could have done it at all without the picture in the manual.
-Ian 1997 Ranger XLT 4x2, 2.3L 4-cyl 5-speed -- 2009 Ranger XLT 4x4, 4.0L V-6 5-speed -- 1986 BMW R80 The advantages of modern engineering are in many ways over balanced by the disadvantages of modern civilization. --Col. W.A. Roebling |
#6
I'll send you (via email) what I have in my Chilton's Manual but it's not that helpful.
#7
I did it a while back, but don't remember much about it, which means it wasn't all that bad. I had the whole rad support out as well...
My trucks: The workhorse, 86 F250 4x4 6.9 nat aspirated, 3.25 exhaust, custom intake, electric fuel pump, otherwise well used stock... not real pretty but just loves to work! The other heavy hauler, 92 F350 2wd dually crew cab, flatbed/toolboxes, 92 Cummins VE 12V with intercooler, NV4500 manual The beater: 88 F250 4x4, 5.8 5 speed The project ... 1978 F150 4wd shortbed 351 auto ASE certified parts specialist I do most all of my own work so I know who to complain to..Roger |
#8
Well just did my whole front end, there are 2 bolts you have to take off to get the bezels and lights out, 2 11mils on the bottom, farly easy to do. On the back on the lower longer amber lights are where the 2 are, then the 2 phillips on the top. if you have to take headlights out, your better off taking the whole header panal out.
The Rides 1999 F250 XLT 240k 6.8L V10 4R100 4x4 X-Cab Long Bed, The New Beauty Queen 1994 Bronco XL 154k 5.0LMAF E4OD 4x4 The Mud Truck/Trail Rig, 1st and Reverse Only 1988 Bronco XLT 156k 5.0LHO AOT 4x4 The Plow Rig/Fully Restored/Beach Cruser Makes The Money To Keep The Rest Nice Other rigs 2003 Mazdaspeed Protege(Parts picker-up-er/ long drives) 1988 Mustang GT 347CI Stroker, Yea its FAST 1991 Mercury Grand Marquis 78k Spotless 1995 F350 XL SOLD
#9
Man Wish I''d paid attention. I've done so many .
But like said 2 nuts in side engine bay 2 on top . Same same . Finding them is fun part they r hid. Can't find em let me know I may have some.
If you can't find a part used u r not looking hard enough.. 94 F150 302 MAf E4od sc long bed 4x4 3:55 LS rears 9MM Ford racing wires MSD cap & rotor and Blaster coil coil . 14-15 MPG Thanks 95 F150 300-6 auto 4x4 8 ft bed barney mobile (yep its purple) . 1 ton front coil and f260 rear leaf suspension Its the plow/firewood truck |
#10
I got I think 2 or 3 pairs of the lower stock ones, and a pair or 2 of the corners, no bezels tho.
| Thread Tools | |
| Display Modes | |
