Old 08-15-2017, 08:47 PM
clutch's Avatar
clutch clutch is offline
clutch will become famous soon enoughclutch will become famous soon enough
rear end
'93 F350, w5spd, u joints replaced last summer,
i can hear clunking when rolling in nuetral, rear end on it's way out?
i replaced the gear oil last month with fresh 80 weight n Lucas Oil Stabilizer.
any recommendations on a good LSD?
"...went back to the old Ford V-8. Can't beat that engine for getting there, oil-burner or no."
William Burroughs, Naked Lunch
Click for Truckee, California Forecast
Old 08-15-2017, 09:13 PM
Fellro's Avatar
Fellro Fellro is offline
Admin
I have had the pinion nut work loose more than once... Snug it up and off we go.
My trucks:
Old 08-16-2017, 04:37 AM
dustybumpers's Avatar
owned by Fords
Agreed.
Maybe add a new seal if it's leaking at the same time.
Charlie
  #4
Old 08-16-2017, 10:06 AM
clutch's Avatar
thanks guys!
  #5
Old 10-09-2017, 02:18 PM
clutch's Avatar
took it to mech. to check he advised u-joints we're bad, n replaced the year Napa ones.
took it home n my transfer case bound up, stick between 2 hi n 4hi, (needed 4wd to get it parked in the back yard), back to mech he found no issues, lubed stuff up, it's better but cant get into 4Lo now... think maybe I left it sittin unused too long?
  #6
Old 10-09-2017, 03:34 PM
owned by Fords
Take the shift tube off, sand, and clean THEN lube
It will easily break, it's only pot metal, and they are HARD to find
Charlie
  #7
Old 10-09-2017, 10:15 PM
clutch's Avatar
shift tube? ��
