Go Back   Ford Truck Fanatics > Engines > 289, 302, 351W
  #1
Old 08-22-2014, 10:35 PM
1970Custom's Avatar
1970Custom 1970Custom is offline
They call me Spuds
1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute
351 heads on a 302
Pros, cons, need to knows.
Пробковыйy
  #2
Old 08-22-2014, 10:39 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
I seem to recall something about the head bolts being either longer or wider and maybe something about the intake gaskets not covering a water passage on real early heads....but it's been a long while....and I think it's otherwise a straight swap.
Quote:
Quote:
Quote:
  #3
Old 08-22-2014, 10:52 PM
1970Custom's Avatar
They call me Spuds
Okay, did some research... Dur...
Quote:
late model 351 heads flow the same as the 302 so if you are upgrading the heads the ones to get are the early style.... But the difference are the bolt size on a 351 windsors are 1/2" and they are 7/16 on 289/302...late model heads have 1.78 intake & 1.46 exhuast valves and early ones have 1.84 & 1.54 & also slightly larger intake and exhaust runners.
Ford began using the same basic head casting for both the 302 and 351W in 1977.
These later 351s, originally identified as 351Ks, have the rectangular 302 intake water passages and 6 intake manifold bolt holes. Original 351W heads have L-shaped water passages and 8 intake manifold bolt holes.
Also, the late model 302/351 heads have a larger water passage at the rear,
which means the intake gaskets are different between early and late models.
If you swap "real" '69-'76 351W heads onto a 302 you need to use the
351W style intake manifold gaskets, as the 302 gaskets will leak water
at the unique 351W intake manifold water ports.
Пробковыйy
  #4
Old 08-22-2014, 11:10 PM
DNFXDLI's Avatar
Admin
My memory still kinda works
  #5
Old 08-22-2014, 11:21 PM
1970Custom's Avatar
They call me Spuds
My Windsor heads are '74 castings so I'm in good shape there...
Or I'll maybe just fix the bottom end of my 351...
Пробковыйy
  #6
Old 08-22-2014, 11:23 PM
DNFXDLI's Avatar
Admin
More cubes = more fun usually.
  #7
Old 08-23-2014, 12:58 AM
Big Jim F150's Avatar
Big Jim F150 Big Jim F150 is offline
73-79 Ford Trucks Rock
Big Jim F150 is a jewel in the roughBig Jim F150 is a jewel in the roughBig Jim F150 is a jewel in the roughBig Jim F150 is a jewel in the rough
There's no replacement for DISPLACEMENT, and big power rules.
Big Jim F150
1978 Ford F-150 Ranger Lariat
  #8
Old 08-23-2014, 11:34 AM
O'Rattlecan's Avatar
O'Rattlecan O'Rattlecan is offline
O'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond repute
Beat me to it. I put 302 heads on the 351, so the opposite, but the machine shop had to bore out the head bolt holes just slightly for clearance.
You might consider sleeving them? I dunno, might be a waste of time.
  #9
Old 08-23-2014, 01:01 PM
5.0Flareside's Avatar
5.0Flareside 5.0Flareside is offline
5.0Flareside has a reputation beyond repute5.0Flareside has a reputation beyond repute5.0Flareside has a reputation beyond repute5.0Flareside has a reputation beyond repute5.0Flareside has a reputation beyond repute5.0Flareside has a reputation beyond repute5.0Flareside has a reputation beyond repute5.0Flareside has a reputation beyond repute5.0Flareside has a reputation beyond repute5.0Flareside has a reputation beyond repute5.0Flareside has a reputation beyond repute
Trick flow sells a spacer for the bolt holes.
And yes your article you quoted has it on the money.
Chris C.
94 F250 7.3 Powerstroke ZF-5.
PREVIOUS: 92 F150 Flareside(white), 87 F250, 92 F150 Flareside (supercab & Red), 88 F-150, 82 F100
  #10
Old 08-23-2014, 03:13 PM
1970Custom's Avatar
They call me Spuds
Quote:
If I could, I'd stick a mild 390 under the hood of the Capri....
Пробковыйy
