  #41
Old 07-06-2018, 12:30 PM
Jasperrc's Avatar
Jasperrc Jasperrc is offline
Texas Chapter member
Started working on the tailgate. Removed the vertical reinforcement at both ends and cut out the rusty bottom edge.
- Russell
'77 F100 Flareside
  #42
Old 07-08-2018, 10:50 PM
fatherdoug's Avatar
Replaced battery, alternator, voltage regulator today. I also ordered and installed a headlight wiring harness with relays and fuses so I can use some 100W/80W bulbs in my Hella headlights.
'78 F-150 Lariat
  #43
Old 09-25-2018, 09:24 PM
fatherdoug's Avatar
Replaced valve cover gaskets on the 400 today. I was starting to smoke the exhaust pipe after 5 minutes of run time. It went better than I thought. The old gaskets(about 12 years old) were dry and brittle.
I tried something different this time - I put Permatex gasket sealant on the valve cover, then put the gasket on the cover and put the bolts through the holes from the inside to hold the gasket in place until the sealant got tacky. I then pulled the bolts and installed the cover, with only one minor adjustment to the gasket to fit the bolts through.
'78 F-150 Lariat
