Go Back   Ford Truck Fanatics > Engines > Other Ford Engines
  #1
Old 05-17-2013, 07:50 PM
aussie_f350's Avatar
aussie_f350 aussie_f350 is offline
aussie_f350 has a reputation beyond reputeaussie_f350 has a reputation beyond reputeaussie_f350 has a reputation beyond reputeaussie_f350 has a reputation beyond reputeaussie_f350 has a reputation beyond reputeaussie_f350 has a reputation beyond reputeaussie_f350 has a reputation beyond reputeaussie_f350 has a reputation beyond reputeaussie_f350 has a reputation beyond reputeaussie_f350 has a reputation beyond reputeaussie_f350 has a reputation beyond repute
2000 ford transit diesel wont start when cold
My brother has a 2000 ford transit turbo diesel, 300.000 km (<200k miles mercon) won't start when it's a frost. He had it at a mechanical workshop and they say the injector pump is failing. Would this only be when it's cold? Runs perfect other than that but has quite a bad injector rattle. Any ideas?
Andy
  #2
Old 05-17-2013, 09:03 PM
dustybumpers's Avatar
My old Ih did that. I would have to plug it in anytime it was below 30* or it would kill the batteries trying to start. Rebuilt the pump, and it started fine when cold without plugging it in. That was an IDI though. Yours is an electric pump in the frame rail.
Charlie
  #3
Old 05-17-2013, 09:27 PM
Quoted around $3k to replace pump!!!! Van is worth 4 at best
Andy
  #4
Old 05-17-2013, 09:50 PM
F 150Cobra's Avatar
F 150Cobra F 150Cobra is offline
"Wild HoRsE" Got Torque?
F 150Cobra has a brilliant futureF 150Cobra has a brilliant futureF 150Cobra has a brilliant futureF 150Cobra has a brilliant futureF 150Cobra has a brilliant futureF 150Cobra has a brilliant futureF 150Cobra has a brilliant futureF 150Cobra has a brilliant futureF 150Cobra has a brilliant futureF 150Cobra has a brilliant futureF 150Cobra has a brilliant future
glow plugs??
Jurgen
F150 1990 blue thunder
F250 1996 Frankenmonster
Bronco 1994 (dad's ride)
Lightning 1994 (restoring)
Aruba.
  #5
Old 05-17-2013, 10:02 PM
1970Custom's Avatar
1970Custom 1970Custom is offline
They call me Spuds
1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute
Either is cheaper...
Пробковыйy
  #6
Old 05-17-2013, 10:26 PM
Forgot to say we did the glow plugs! And yes give him a can of start ya bastard!!!
Andy
  #7
Old 05-18-2013, 07:22 AM
Does it do better plugged in?
You might also want to check for air leaks. look around the filter housing, , or any lines.
Even the gasket on the filter housing could be marginal.
Try cycling the key, and letting the elec pump run a few times to see if it starts better
Charlie
  #8
Old 05-18-2013, 07:55 AM
We don't plug them in over here. I haven been over to look at it lately but I will tomoro. I have the auto enginuity software so will plug that in
Andy
  #9
Old 05-18-2013, 06:20 PM
kiwi f150's Avatar
kiwi f150 kiwi f150 is offline
kiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond repute
Andy when you put the new glow plugs in did you test the controller? How long do the plugs glow for?
just make sure you disconnect the glow system before firing a shot of "start ya bastard" down it's throat
Cheers Mark
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rapidly promoted by mainstream media, which holds forth the proposition that it is entirely possible to pick up a piece of sh*t by the clean end."
  #10
Old 05-18-2013, 06:34 PM
I didn test the glow plug relay, but the glow plugs stay on longer now than before. He hasn't used the spray yet but that's a good point! Hadn't thought about that
Andy
