Go Back   Ford Truck Fanatics > Superduties & Other Trucks > Superduty Gen.2
Superduty Gen.2 2008-2010 F250, F350, F450, F550
  #21
Old 05-25-2018, 09:37 AM
Blacktruckdave's Avatar
Blacktruckdave Blacktruckdave is offline
Blacktruckdave is on a distinguished road
Quote:
Originally Posted by dustybumpers View Post
That would be the 3/4 ton
I would measure the lines on the truck.
My guess, your truck will take the shorter hose, but measure to be sure
Thanks for your response.
I'm racking my brain on this issue. I can't believe no one else in this forum has had to face this decision. 21.25" or 22.63" I am leaning towards the longer ones because it's 1.38" difference we are talking about length wise. Everything else seems to be the same. The lines are also rubber so why not be safe than sorry. Just boggles me that the search function in this forum leads me nowhere.
Brakes are a big topic. Even inputting my Vin # still gives me both lengths.
  #22
Old 05-25-2018, 04:51 PM
dustybumpers's Avatar
A word of caution on a brake line that is too long.
Be sure it don't rub the tire on a lock to lock turn.
If it ends up you put the longer line on where the shorter one was, you should be fine, just make sure it has clearance.
We here give you the great big star award for being the first to come up against this problem
Charlie
  #23
Old 05-25-2018, 09:39 PM
fatherdoug's Avatar
My truck always pulls to the right when passing a dairy queen. Sorry, couldn't resist.
'78 F-150 Lariat
Quote:
Quote:
  #24
Old 05-26-2018, 08:41 AM
What happens if there's a Wendys on the left with .50 frosty's?
Charlie
  #25
Old 05-26-2018, 07:26 PM
fatherdoug's Avatar
Then it pulls to the left...….
'78 F-150 Lariat
  #26
Old 05-26-2018, 07:37 PM
Dustybumpers likes that post
Charlie
  #27
Old 06-05-2018, 02:47 PM
My truck doesn't pull for junkfood but it did turn out to be one of the front brake hoses. My parts came and I installed them today. Turns out mine was the 22.63" also. Victory at last. Thanks for everyones input. Mucho Apreciated!
  #28
Old 06-05-2018, 04:15 PM
Sparky83's Avatar
Sparky83 Sparky83 is offline
Virginia Chapter member
Quote:
Originally Posted by Blacktruckdave View Post
So checking with the aftermarket stores there are 2 different lengths for the front brake lines. One is 21.25" and the other is 22.63". Both say female 3/8th - 24 and Banjo .375.
Why the 2 different lengths?
Some will label the different hoses as the Narrow and Wide Frame options... (factory flat bed/cab & chassis frame. vs standard bed boxes) i didnt understand it either when i was searching for the flex hoses on mine the first time. thought they were referring to the SRW and DRW options there... but the beds are same bolt pattern there... i went with narrow frame ones now realizing what they were referring to.. the narrower frames use the slightly longer hoses to reach the fittings.. where the wider frames didnt. i didnt have any rub issues then... some of the parts stores have updated their sites to make this less confusing others havent.
Shawn
2004 3.9L V6 Mustang
-John F. Kennedy
-Christopher Titus
