Go Back   Ford Truck Fanatics > F-Series > Generation 1
Generation 1 1948-1952 F1 thru F8
  #21
Old 10-22-2013, 06:24 PM
black_devil's Avatar
black_devil black_devil is offline
babble babble
black_devil is on a distinguished road
Does anyone know what the lug pattern is its the 8 lug wheel.
droid jkf2 1950
  #22
Old 10-22-2013, 09:35 PM
mtflat mtflat is offline
Flatheads Forever
mtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond reputemtflat has a reputation beyond repute
8 on 6.5"
It's the same pattern Ford used until '96 on 3/4 ton trucks. Makes it super easy to find alternative wheels.
'97 on are metric
...Tim
  #23
Old 10-28-2013, 06:11 PM
babble babble
So I have come across a problem I have many cancer spots on my truck and bending metal for some of these spots is out of the question so is bondo or fiberglass better for a seamless and as close to original as possible. ( I don't want the thud when knocking on the body)
droid jkf2 1950
  #24
Old 11-02-2013, 03:44 PM
babble babble
Made some progress this weekend torn into the engine more
droid jkf2 1950
  #25
Old 11-20-2013, 04:05 PM
babble babble
Ok can't post anymore photographs so how do I remove the bolts for the door there a Phillips head bolt and I have pretty much stripped it
droid jkf2 1950
  #26
Old 11-20-2013, 04:14 PM
Flatheads Forever
They're tough to remove. A driven bit usually gets them, but with the heads stripped you'll probably have to drill them out.
The early F series trucks had a spot of weld to hold the hinges in place.
You could pull the pins if you just want to remove the doors, but those aren't usually easy either - I ended up drilling mine out.
...Tim
  #27
Old 11-20-2013, 04:25 PM
babble babble
Crap well looks like I'm going to be drilling
droid jkf2 1950
  #28
Old 11-21-2013, 09:26 PM
49fordv8f4's Avatar
49fordv8f4 49fordv8f4 is offline
49fordv8f4 is on a distinguished road
Your '50 F2 is the same color as my '49 F4. I've got the cab repainted on mine, I used Du Pont Nason Urethane in Holly Red. It is very close to the original color and available as a premixed color, so it was a little cheaper than custom mixed paint.
Mark
  #29
Old 11-22-2013, 01:37 PM
babble babble
Nice I'm planning to repaint it a matte black so the red cab and yellow bed just don't match and I invisioned it a black all along
droid jkf2 1950
  #30
Old 06-18-2014, 05:02 PM
EdKenleyFordUT EdKenleyFordUT is offline
EdKenleyFordUT is on a distinguished road
Nice project, best of luck!
