Go Back   Ford Truck Fanatics > Engines > 351M, 400
  #1
Old 06-15-2014, 02:36 PM
Ridgerunner's Avatar
Ridgerunner Ridgerunner is offline
Ridgerunner has a reputation beyond reputeRidgerunner has a reputation beyond reputeRidgerunner has a reputation beyond reputeRidgerunner has a reputation beyond reputeRidgerunner has a reputation beyond reputeRidgerunner has a reputation beyond reputeRidgerunner has a reputation beyond reputeRidgerunner has a reputation beyond reputeRidgerunner has a reputation beyond reputeRidgerunner has a reputation beyond reputeRidgerunner has a reputation beyond repute
351 M
I have a chance to buy a 351M with a C6 Trans for $200.00
I was wondering what it would take to make a good low to mid range HP & Torque engine, is it hard to do, what series engine are these?
I have found a T Bucket Kit that I think this would be good to put in after being rebuilt.
Please Vote It's a great way to bring more members.
1998 Ford Expedition 4X4
2000 Mustang Drop Top
  #2
Old 06-15-2014, 02:43 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
335 Series Cliff....there is tons of info here if you do a quick search, but they respond the same as any other engine with basic mods.
Other things like changing the crank to a 400 crank will give you an instant 50 cubes and then there are things like the closed chamber Australian heads.
You should check out Tim Meyer's site
Quote:
Quote:
Quote:
  #3
Old 06-15-2014, 02:48 PM
I did and I forgot to take my stupid pills this morning.
Thanks for telling me the series so I know now how to look it up. I wonder how hard it is to find a 400 crank here? So this is a small block on steroids almost?
  #4
Old 06-15-2014, 02:51 PM
DNFXDLI's Avatar
Admin
Np..and I'm sure there are still some at autowreckers....but then don't forget you are going to have to get it checked...adds a lot more work than just doing bolt-on's.
  #5
Old 06-15-2014, 02:53 PM
Here is the ad, if it is correct it maybe ok.
http://tulsa.craigslist.org/pts/4521467418.html
Would rebuilt 400 heads be ok from Tim Meyers?
  #6
Old 06-15-2014, 02:57 PM
DNFXDLI's Avatar
Admin
No idea.....but if you can't see it running I would be leery...you'd need to pull the plugs and maybe the valve covers .
If I couldn't see it running and operational in a vehicle..esp with a transmission attached, I'd be prepared to wind up spending $$ on it.
  #7
Old 06-15-2014, 02:59 PM
DNFXDLI's Avatar
Admin
If you are going to go to the length of heads, then it would be wisest to go with the CC Aussie heads....but then you will be looking at pistons as well....which will then mushroom into a complete rebuild.
  #8
Old 06-15-2014, 03:00 PM
Yeah I am kind of worried about that. It is the only Modified in my area. Even the 302 is hard to find. I found several 460 but I ain't interested in them. I really don't want to take a chance on the wreckers but may have to.
  #9
Old 06-15-2014, 03:01 PM
I had planned a full build. I don't want to drop a engine in a T Bucket and have it let go after starting it.
  #10
Old 06-15-2014, 03:15 PM
DNFXDLI's Avatar
Admin
True enough....did you read Tim's 400 build?
http://www.tmeyerinc.com/category-s/1889.htm
