Go Back   Ford Truck Fanatics > Superduties & Other Trucks > Bronco
Bronco Full Size Bronco Discussion
Old 02-11-2019, 11:48 PM
torino71 torino71 is offline
torino71 is on a distinguished road
How to weld fix on a Bronco stress cracks adjacent to the steering box on the cross member
Any tips or kits or How to perform a better weld fix on a Bronco stress cracks adjacent to the steering box on the cross member bottom to chassis on a 1986? XLT
I feel that a local parts and tire auto place placed the rack arm on the wrong place while lifting, and a day or so the steering wheel went sideways to the right,
I had a performance muffler shop weld like a metal U sandwich plate it lasted for 3 months, and reading some threads I saw they used a fix with longer bolts on a 4WD 79, and weld or thicker plates , or some kit, Any help is appreciated thanks up front
Old 02-12-2019, 12:26 AM
Sparky83's Avatar
Sparky83 Sparky83 is offline
stop drill the ends of the cracks and then grind down the frame along the crack.. once thats done weld it back up... when your done grind the weld flush... if you wish you can also weld a gusset plate around the outside of the frame to give it additional support..
Shawn
2004 3.9L V6 Mustang
-John F. Kennedy
-Christopher Titus
Old 02-24-2019, 04:41 AM
heavydoc's Avatar
heavydoc heavydoc is offline
heavydoc is a splendid one to beholdheavydoc is a splendid one to beholdheavydoc is a splendid one to beholdheavydoc is a splendid one to beholdheavydoc is a splendid one to beholdheavydoc is a splendid one to beholdheavydoc is a splendid one to behold
Are the bolts just going through the frame or are there tubes in the frame for the bolts to go through. The lack of or missing tubes could be the culprit
Sent from my SM-N920V using Tapatalk
96 F-350 RCLB DRW 2WD
01 Excursion Limited 4WD
02 F-350 CCLB DRW 4WD
20 Kenworth T270
"DOC"
Tags
chassis crossmbr weld
