interesting study and article here
they basically tested a bunch of NYC cabs with different oil doing oil changes at 6,000 miles. tore the engines down and found virtually no differences in them
After each engine ran about 60,000 miles (and through 10 months of seasonal changes), we disassembled it and measured the wear on the camshaft, valve lifters, and connecting-rod bearings. We used a tool precise to within 0.00001 inch to measure wear on the key surfaces of the camshaft, and a tool precise to within 0.0001 inch on the valve lifters. The combined wear for both parts averaged only 0.0026 inch, about the thickness of this magazine page. Generally, we noted as much variation between engines using the same oil as between those using different oils. Even the engines with the most wear didn't reach a level where we could detect operational problems.
We measured wear on connecting rod bearings by weighing them to the nearest 0.0001 gram. Wear on the key surface of each bearing averaged 0.240 gram - about the weight of seven staples. Again, all the tested oils provided adequate protection.
