Go Back   Ford Truck Fanatics > F-Series > Generation 4
Generation 4 1961-1966 F100, F250, F350
Old 02-06-2018, 04:08 PM
bryoung14's Avatar
bryoung14 bryoung14 is offline
bryoung14 is on a distinguished road
Brake help.
Just towed my truck home after having i beams from a 74 f100 and disc brakes installed. Guy who started didn't have time to finish so I'm trying to figure out how to runs new lines/adjustable proportioning valve and whatever else I need to get brakes on this thing.
My question is, how hard is this to finish up? I'm new to this stuff, but am pretty good wrenching on things.
Sent from my Pixel using Tapatalk
Old 02-06-2018, 07:23 PM
Fellro's Avatar
Fellro Fellro is offline
Admin
Check out a 74 or so truck and see how they did it and just mimic that. Might even be able to use the proportioning valve from the same age truck as I doubt (without looking it up) that the brake sizing is much different. Need the master setup as well. Possibly you might be able to reuse the steel lines that were there for the drum brakes unless are different size, don't remember without looking.
My trucks:
Old 02-06-2018, 09:53 PM
cbaker65's Avatar
cbaker65 cbaker65 is offline
I would think the booster would be a little bit rough to figure out ,they have aftermarket stuff that may fit your application ,just do some homework
on that for bolt patterns & set ups!
CB
  #4
Old 02-11-2018, 11:55 PM
BKW's Avatar
BKW BKW is offline
Ford Parts Guru
BKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant future
D3TZ-2B257-A .. Brake Pressure Differential (aka proportioning) Valve / Marked: D3TB-2B524-AA / Obsolete
1973/74 F100 2WD & F250 2WD with 6,200 lbs. GVWR that have single piston caliper disc brakes.
1973 F100 2WD was the first to have disc brakes. Manual discs were standard equipment, power discs were optional.
2017 Fusion SE
