Go Back   Ford Truck Fanatics > F-Series > Generation 7
Generation 7 1980-1986 F150, F250, F350
  #1
Old 10-15-2016, 04:43 AM
Paparobert13 Paparobert13 is offline
Paparobert13 is on a distinguished road
1984 control module problems
I need help. My "baby" is 1984 F150, 300 - 6 It has run beautifully for quite awhile. Started destroying ignition control modules. I have went throug 4 so far. I have replaced the distributor, cap and button, also replaced coil, fuel pump, and filter. The last control module , I went with the more expensive BWD at triple the cost. Worked great for two weeks. It now is seeming defective and engine quits. If I unplug the connector and reconnect, it will start again and run for a little while. What do I do next? Replace ECM? If possible wiring problems, (nothing has ever been done with this, stock) what do I look for etc? Can. Anyone help?
  #2
Old 10-15-2016, 06:55 PM
BKW's Avatar
BKW BKW is offline
Ford Parts Guru
BKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant future
Quote:
E43Z-12A297-A .. TFI Ignition Module-Located on Distributor (Motorcraft DY-425) / Marked: E3EF-12A297-A1A or A2A / Available from Ford & auto parts stores.
This module has been a notorious POS since day one! About 15 years ago, the US Gov't forced FoMoCo to recall over a million vehicles to replace the turds.
Today, the problem is even worse, with auto parts stores selling made in China crap!
Bill / Retired Ford Parts Manager / Part Number Research: 1928/2001 FoMoCo vehicles.
2017 Fusion SE
  #3
Old 10-15-2016, 10:36 PM
Thanks for the reply. I purchased another module today from another parts store. The last one is covered by warranty but had to order it. Going to take a few days. The one I purchased today says made in USA by BWD has me back on the road. I'll pick the other one up and I guess will have a spare. I cleaned a couple grounds and reconnected and also removed the ECM and cleaned pins. Nad reconnected. I pray this one will last?????? What else can I do ?
  #4
Old 10-16-2016, 09:15 PM
dustybumpers's Avatar
Make sure to coat the back of it with the dielectric grease that was supplied with it, or the new one will fail soon too
Charlie
  #5
Old 10-18-2016, 06:34 AM
crazycanuck's Avatar
crazycanuck crazycanuck is offline
crazycanuck has a spectacular aura aboutcrazycanuck has a spectacular aura about
X2 on the grease!!
