Go Back   Ford Truck Fanatics > F-Series > Generation 7
Generation 7 1980-1986 F150, F250, F350
  #21
Old 03-05-2015, 11:18 PM
oneribshy's Avatar
oneribshy oneribshy is offline
Bend guy
oneribshy is on a distinguished road
had a idea I am going to ad a 12 volt RV water pump to my heater hose from the pump and when I turn my heater on it will turn on the pump and pump the water through the core... This is the weakest pumping system I have ever seen.
  #22
Old 03-06-2015, 05:45 AM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
The only thing that worked for me was to increase the idle rpm with a stick wedged between the seat and the pedal.
I even bought a small electric heater to assist it on really cold mornings.
Click for weather forecast
________________
Randy
  #23
Old 03-06-2015, 09:39 AM
Fellro's Avatar
Fellro Fellro is offline
Admin
While I doubt it is the only reason, the 160 degree thermostat isn't helping matters much either. Should be a 190-195.
My trucks:
  #24
Old 03-06-2015, 08:47 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile CowboyBilly9Mile is offline
CowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond repute
Quote:
That, and I'd encourage the usage of a Motorcraft T-stat. For whatever reason, the 2.3 3.0 and 4.0 in the Rangers just doesn't seem to do well with aftermarket t-stat brands.
*For good measure, you could inspect yours to verify that it's fully closed when cold.
-Bill
-Life is far too short to be serious all the time. So if you can't stop and laugh at yourself along the way, give me a call and I'll do it for you.
04 Ranger Fx4 Level II, 5R55E, Sonic Blue Pearl, loaded.
Useful Ford Vehicle Resources:
Owners Manuals >>> http://www.fleet.ford.com/partsandse...owner-manuals/
Build Information (click on "vehicle") >>> https://www.etis.ford.com/
Wiring schematics and TSB's (click on "technical information") >>> http://bbbind.com/
Repair guides, includes schematics w/connector pinouts >>> http://www.autozone.com/repairinfo/r...nfoLanding.jsp
  #25
Old 03-07-2015, 09:58 AM
oneribshy's Avatar
Bend guy
The thermo was the problem
Well Guys it was MY FAULT!!!! I took the truck in yesterday to a mechanic for a tune up... Had him look at a few things while it was in there....Anyway it was the thermostat the whole time. It was the first thing I replaced! It was the wrong one. Not knowing there are different looking ones. So replaced it with the same looking one that was in it when I got the truck. Hence why it didn't work to begin with. Anyway Thanks guys for all your advice....PROBLEM SOLVED....Now I have a two heater cores-three water pumps, on hand because of my ignorance. But hey now when those item go out eventually I'll have them.....LOL! OH HAPPY DAYS!!!!
  #26
Old 03-07-2015, 10:09 AM
Fellro's Avatar
Admin
Thermostats can be a real headache to figure out when you assume they are fine and all. They just set the temp, and if they allow bypass, or are stuck open, they will make it seem like there is no heat. It seems the one in my daughter's car is an annual thing, as I just had to do it again. She complained of no heat, so I got that, and what a surprise, stupid thing was stuck open. Still is open after laying on the bench for a few months... I had the benefit of a temp gauge on that case though, so I could see it wasn't getting warmed up enough.
My trucks:
  #27
Old 01-17-2017, 05:02 PM
oneribshy's Avatar
Bend guy
I had the wrong thermostat in it is all. I just got the same one that was installed by the previous owner thought it was the right one....WRONG So all this was a waste of time.
