Go Back   Ford Truck Fanatics > Engines > 4.6L/5.4L/V10 Modulars
  #31
Old 05-28-2016, 12:16 PM
CowboyBilly9Mile's Avatar
You guys with the modulars and the sticky spark plugs.........story I got ~3-4 years ago, which came from a Ford Engineer on duty at the Ford display at SEMA, was that the original tolerance over that longgggggg length of reach down into the CC allowed for variations that could result in what amounted to, a slightly egg shaped diameter over that section. Obviously with carbon in there, this could cause a sticking problem.
So after learning about this some time ago and theoretically one would assume a revision to the plugs was made, are there still issues when the current version of Motorcraft or Autolite plugs are used?
-Bill
-A wise man learns from his mistakes; a wiser man learns from the mistakes of others.
  #32
Old 04-17-2018, 01:17 AM
amkatt1's Avatar
amkatt1 amkatt1 is offline
amkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond repute
An update on changing the plugs for my 2001 4.6 Triton.
I ended up getting all new FoMoCo coils online in a factory sealed bag for each coil. Also new Motorcraft plugs. I also bought a few extensions in different lenghts.
I watched a great YouTube video and found/saw that the fuel rails do not need to be removed!
Removing the coil packs was easy for me. Even the back ones. There were two that were in terrible condition! I was getting a slight misfire on damp mornings. With the coils removed, I used an air blow gun nossle with a long tip to blow out any debris before removing the plugs. Plugs were tight but all came out with no issues. Having a telescopic magentic wand made it very easy to remove the plugs from the Modular head.
I took my time and it only took me 6 hours!
What a long overdue tuneup!! Plugs were very worn too.
Mileage is back to 15-17 mpg. Much better performance too!
Roy
yeeooow!
  #33
Old 05-28-2020, 05:04 PM
amkatt1's Avatar
Been 2 years ago now since I changed the coils and plugs. No issues at all
Roy
yeeooow!
  #34
Old 05-28-2020, 05:17 PM
fatherdoug's Avatar
Glad to hear!
'78 F-150 Lariat
  #35
Old 05-29-2020, 01:17 AM
amkatt1's Avatar
Glad to hear!
Thanks Doug. Pays to use original OEM parts. Guys buying cheap coils that fail after a short time, waste of time and money.
Roy
yeeooow!
  #36
Old 06-09-2020, 12:42 PM
Jasperrc's Avatar
Jasperrc Jasperrc is offline
Texas Chapter member
Jasperrc has much to be proud ofJasperrc has much to be proud ofJasperrc has much to be proud ofJasperrc has much to be proud ofJasperrc has much to be proud ofJasperrc has much to be proud ofJasperrc has much to be proud ofJasperrc has much to be proud of
Especially when the job takes 6 hours, that's worth the extra money for good parts!
- Russell
'77 F100 Flareside
  #37
Old 06-11-2020, 07:06 PM
amkatt1's Avatar
Roy
yeeooow!
  #38
Old 09-11-2020, 12:40 PM
davidvachon69 davidvachon69 is offline
davidvachon69 is on a distinguished road
I bought a 2000 F-150 with the 4.6. The previous owner broke off a coil bolt flush. I changed the plugs and broke off the part that holds the coil down. Any idea would be appreciated.
  #39
Old 09-13-2020, 07:41 AM
heavydoc's Avatar
heavydoc heavydoc is offline
Instigator
heavydoc is a splendid one to beholdheavydoc is a splendid one to beholdheavydoc is a splendid one to beholdheavydoc is a splendid one to beholdheavydoc is a splendid one to beholdheavydoc is a splendid one to beholdheavydoc is a splendid one to behold
Can you get in with a washer or nut and weld it to the broken bolt?
96 F-350 RCLB DRW 2WD
01 Excursion Limited 4WD
02 F-350 CCLB DRW 4WD
20 Kenworth T270
"DOC"
  #40
Old 11-21-2020, 02:47 AM
amkatt1's Avatar
Drill and re tap, or try a easy out first. Itís such a small bolt too.
Roy
yeeooow!
