Home | Gallery | TOTM | New Posts | My Threads / My Replies | Links | Sponsors | Calendar | Arcade | Calculators | Fliers |
Generation 4 1961-1966 F100, F250, F350 |
Thread Tools | Display Modes |
my 66 eff series
Hey, been on here for a while. Ive owned the 66 for a little over 2 weeks now.
This is how it sat for over a year at my buddys house. I traded a Motorcycle I restored for this truck. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Its a decently solid truck, I have the origional door, and such. First thing I did was ripped out the wood slats and trim in the bed. The axle had been welded upside down (which explains the PO not being able to hook the driveshaft and parking brakes up) so the axle was ripped out, new axle perches ordered and old taken off the axle. The brakes got torn down, and the axle was just torn down tonight. Progress is slow right now, as im waiting for parts and weather hasnt been the best. I got the leaf spring bushings as the leafs are good, all new brakes are awaiting installation, and the rear end parts are on order. Tomorrow the bed comes off and some frame clean up will happen. I am wild in my designs, and I had the rendering for this truck done before I even had it. Ill have updated pictures tomorrow. But Im hoping most things dont need replacing, I mean the god damn thing has 59xxx original miles!!! More pics to come, and questions will arise |
Sponsored Links |
Looks like a great start you've got there.
Cheers Mark "Political correctness is a doctrine, fostered by a delusional, illogical minority, and rapidly promoted by mainstream media, which holds forth the proposition that it is entirely possible to pick up a piece of sh*t by the clean end." ![]() |
it is. Im looking for a transmission and bellhousing for my 351, then ill check compression and give it a mild build, then drop it in the truck
![]() got my sheet metal from work. It came off a 2003 Dodge ram long bed, the metal is the same thickness, so once I start my body work ill be able to make any patch panels I may need instead of buying them. The goal is to buy only a tail gate and make the rest of the patches myself. ![]() ![]() The rear end is also torn down. The outter axle shaft bearings are in great shape. The bearings for the pinion, the seals, and the inner axle bearings all have some play, so those will be replaced. The pinion bearings and seals have already been pressed out. ![]() ![]() The origional door also got stripped down today as its not salvagable. Bondo chunks 1/8 and 1/4 inch thick are falling off it already. here is the ID plate too, if someone could run that for me and let me know what it means? I should have my brake drums back today, and should have all my bearings in it and have the axle and rear end rebuilt this week. Going to relocate my gas tank, and the plan is to also use a 1966 Mustang tank, and fit it between the frame rails, and hide the filler neck somewhere. Anyone done this or have any ideas? Id like to stay away from cutting into the bed, but I dont mind if I have to. I hope to run it out the side or rear of the bed, but we will see once the tank is here. Last edited by Big_Texxan; 09-19-2015 at 03:44 PM. |
#4
Cool project!
According to my 1966 book, if I am decoding properly.. F10..........F100 A.............240cid 6cyl N.............Norfolk assembly 816088.....Feb 1966 115..........115" wheelbase F101.........4200# 3..............Green vinyl interior 81............Conventional cab C..............3 spd Ford light duty transmission 05.............4.11 3300# axle 129hp@4000rpm DSO...District Sales Office...number doesn't jibe with my book....sez the "90's" are export...DSO codes in book go from 11 to 89 If I'm off on any of this stuff, I am sure Bill (BKW) will correct it
#5
Bill / Retired Ford Parts Manager / Part Number Research: 1928/2001 FoMoCo vehicles. 2017 Fusion SE Last edited by BKW; 09-30-2015 at 06:24 PM. |
#6
Thanks Bill...still learning!
#7
Can't wait to see this project completed
Roy yeeooow! |
#8
If you are not intending to use it as a hauler, then you could make and access door in the wood in the bed for the fuel fill. Otherwise not a lot of options that don't involve cutting into the bed.
My trucks: The workhorse, 86 F250 4x4 6.9 nat aspirated, 3.25 exhaust, custom intake, electric fuel pump, otherwise well used stock... not real pretty but just loves to work! The other heavy hauler, 92 F350 2wd dually crew cab, flatbed/toolboxes, 92 Cummins VE 12V with intercooler, NV4500 manual The beater: 88 F250 4x4, 5.8 5 speed The project ... 1978 F150 4wd shortbed 351 auto ASE certified parts specialist I do most all of my own work so I know who to complain to..Roger |
#9
Thanks guys. I got the gas tank and the parking brake cables ordered since the old ones were not too good. The passenger side had frayed and split, and someone took some hose and zip tied it around the broken strands to keep them from hanging loosely. I should have my tank and cables tomorrow.
I didnt get anything done today as Im always working side jobs and such. Had a co-admin for another place bring his R6 bike for some welding and other minor things over to my place, and I felt like taking a lazy sunday. My truck is on the right ![]() |
#10
update. no work this week, lost a friend and weather has been s****y. i did get my parking cables and gas tank, so maybe this weekend if I dont work on another vehicle I have or have customers blowing me up. I work, and run my own business. This is always the last thing or stress reliever.
Tags |
american, f100, ford, georgia, texas |
Thread Tools | |
Display Modes | |
