Heater Hose Routing
Can someone tell me the correct heater hose routing on a 1977 F100 with a 302 engine? There are two outlets on the thermostat housing (one on the top and one on the front) and two on the side of the water pump. Which ones go to the heater and which one of these should have the normally closed in-line vacuum valve? Thanks.
The outlet beside the rad hose is the bypass that goes to the water pump, the threaded port is either vac switch or plugged.
