Go Back   Ford Truck Fanatics > Engines > 6.7 Powerstroke
  #81
Old 10-05-2013, 01:29 PM
blacksnapon's Avatar
blacksnapon blacksnapon is offline
Super Moderator
Super Moderator
blacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond repute
Quote:
Originally Posted by suprdtydvr View Post
Vince, do you think that TSB 12-11-11 applied here? I see it was a 2011 F-550.
http://www.fordservicecontent.com/pu...sb12-11-11.pdf
Is there any physical difference between the factory supplied block and the "long block" that is directed for replacement? Do you know if there is any documentation on the design change to the head that prevents the valve insert from releasing?
Yep, thats the one that I followed. You get paid 18.3, and it took closer to 30. Only difference I saw was different glow plugs are used (overall same length, but seat to end of glow plug is shorter.
ase master tech--fmc senior master tech (retired)
