Go Back   Ford Truck Fanatics > Superduties & Other Trucks > Superduty Gen.1
Superduty Gen.1 1999-2007 F250, F350, F450, F550
  #1
Old 09-15-2017, 05:11 PM
magnum136 magnum136 is offline
magnum136 is on a distinguished road
Where is the power door lock relay located on 2004 F350 XL crew 4x4 V-10 basic truck
Im testing my basic factory door locks on my 2004 V-10 crew cab 4x4 F350. All four door actuators click about every 20 seconds, neither locking or unlocking, and if I do lock a door it will unlock itself automatically with in 20 seconds. I found that removing fuse # 102 does nothing. Removing the key or starting the truck, makes no difference either. I arrive home from work and I cant lock my doors. If I lock the drivers door when exiting the vehicle, (which should lock all 4 doors and doesn't), then only the drivers door actually locks and it only stays locked about 20 seconds. When I'm driving to work all 4 locks are clicking about every 20 seconds(neither locking or unlocking). I have to remove the battery cable and lock each door manually at night in order to secure the vehicle.
"I'm in need of the exact location of the power door lock relay or relays". My plan is to remove the relays, fuse #102 , and unplug all power wires inside each truck door to kill all power to this door lock circuit, and keep it from draining my battery down when I don't drive the truck every day. I'm looking for the door lock relay(s). There doesn't appear to be a VSM on this basic truck which only has basic power door locks, as its only interior luxury option. Thanks
  #2
Old 09-16-2017, 01:06 AM
Sparky83's Avatar
Sparky83 Sparky83 is offline
Virginia Chapter member
id have to look tomorrow.. but i know theres a fuse or 2 under the dash.. and more under the hood in the master block.. transcevers behind the dash but not sure exactly where... the one in my truck is an aftermarket remote..from the sounds of it though you might have a switch thats shorting out.. that or the transceiver is..
Shawn
2004 3.9L V6 Mustang
-John F. Kennedy
-Christopher Titus
