Go Back   Ford Truck Fanatics > General Maintenance, Performance, and Tech. Info > General Automotive
General Automotive Technical Catch-All
Old 08-04-2019, 11:31 PM
bradleyheathhays bradleyheathhays is offline
bradleyheathhays is on a distinguished road
Tracking / steering issues
My '11 Crown Vic has got 315k miles on it and I'm having some kind of tracking problem that I think is coming from the steering. If there's not much wind it drives straight down the road just fine up to about 60 mph. But if the winds up some, or if I take it up to 70, it's tracking characteristics start to get weird and unsettling. Rain seems to cause it to get worse as well. The feeling is not dissimilar to hydroplaning.
I got the wheels off the ground and pushed/pulled on all the tires..3 and 9 o'clock, 6 and 12. Back wheels were solid, and the fronts were ok when I did the 6 and 12, but on the 3 and 9 test the tires moved about 1/4". They didn't move easily say as if they were completely loose, but it didn't take all that much effort to get them rocking either. At each limit of movement there's a low grade thud that's coming from somewhere between the two wheels, pretty close to the center of the car I'd say. I don't know if the movement I'm seeing is normal, but the degree the steering seems to be unpredictable would seem to correlate to about the degree of movement I'm seeing with the 3 and 9 test.
Any ideas on where I go from here?
Old 08-06-2019, 12:30 PM
68F1006.4's Avatar
68F1006.4 68F1006.4 is offline
68F1006.4 is a glorious beacon of light68F1006.4 is a glorious beacon of light68F1006.4 is a glorious beacon of light68F1006.4 is a glorious beacon of light68F1006.4 is a glorious beacon of light
Sounds like a toe issue to me. I had that same issue on my 85 Foxbody and it turned out to be worn end links on the steering rack.
On a side note, I just picked up an 07 Vic with 72k miles and seeing that you have 315k miles makes me feel good about my purchase.
Bow low before God, stand tall before man, and stand firm in the gap.
Old 08-06-2019, 03:29 PM
dustybumpers's Avatar
Best to lay under the front of the car, have someone shake the steering wheel back and forth and watch the steering links for wear.
I agree, It's probably outer tie rod ends.
Charlie
  #4
Old 08-06-2019, 04:37 PM
buckiniowa buckiniowa is offline
buckiniowa is on a distinguished road
Hi Bradley. My first post here but I can answer this. I have 2 Grand Marquis of the same generation. You need a new steering rack. They wear and get play after about 150k. Causes a loose feeling in a crosswind or road unevenness. Atlantic Steeriing products does a nice rebuild model.
  #5
Old 08-13-2019, 05:51 PM
Thanks for the good advice everybody and sorry it took so long to get back. Just got the car back from a front end inspection and they're saying my biggest problem is that both lower ball joints need to be replaced. I've done work similar to this before (using a pickle fork to separate joints and using a rented ball joint press) but they were advising it might be too tough of a job to do by myself in my driveway. I have a 1000lb impact wrench but only a really small compressor.
What do you guys think about attempting this job myself? Any advice?
  #6
Old 08-14-2019, 11:53 AM
BKW's Avatar
BKW BKW is offline
Ford Parts Guru
BKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond reputeBKW has a reputation beyond repute
2003 and later Crown Vics/Grand Marquis have rack and pinion steering.
2017 Fusion SE
  #7
Old 08-15-2019, 02:05 AM
Well I've decided I'm gonna give it a shot at doing this myself. 'Couple' questions...
- I know the lower BJ presses out, but does the top one press out as well?
- Does the sway bar link have to come off for better access?
- Anything else I should change out while I'm in there? So far I'm gonna be doing both upper and lower BJs and probably the tie rod ends.
- I've been told to use green loc tite. That would be used on the threads on the bottom of the BJs?
- Also been told to watch out for the spring shooting out at me but I believe I have a shock in spring, a strut? Is there any danger of this spring suddenly popping out after tension is eased? I don't plan on removing the spring at all.
- The Moog BJ I'm considering at Rockauto doesn't appear to have a grease boot. Am I looking at this picture wrong? Is that black part a boot that will expand when it's filled up?
  #8
Old 08-15-2019, 06:49 AM
Do all 4 ball joints, and both outer tire rod ends
You will need a ball joint press
Charlie
