Go Back   Ford Truck Fanatics > Superduties & Other Trucks > Transit/Transit Connect
  #1
Old 03-31-2014, 07:24 PM
blacksnapon's Avatar
blacksnapon blacksnapon is offline
Super Moderator
Super Moderator
blacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond repute
special service message
Mar 28 2014 4767 -2014 Transit Connect - Ignore DTC B10C0:15 - Built On Or Before 3/24/14
Some Transit Connect vehicles built before 03/24/2014 may exhibit DTC B10C0:15 (Fuel Pump Supply) in the Body Control Module (BCM). Ignore this code, even if a no start condition exists. It is not related to the no start and the DTC has been turned off in a newly released BCM configuration. Refer to symptom based diagnostics in the Workshop Manual if there are no other DTCs present.
ase master tech--fmc senior master tech (retired)
