Go Back   Ford Truck Fanatics > Superduties & Other Trucks > Superduty Gen.1
Superduty Gen.1 1999-2007 F250, F350, F450, F550
  #11
Old 01-19-2016, 11:34 PM
1970Custom's Avatar
1970Custom 1970Custom is offline
They call me Spuds
1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute1970Custom has a reputation beyond repute
So why heat on auto but as soon as I flip to defrost it gets cold? I can switch right back to auto and it'll warm back up?
Пробковыйy
  #12
Old 01-20-2016, 12:27 AM
polarbear's Avatar
polarbear polarbear is offline
just growing older not up
polarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond reputepolarbear has a reputation beyond repute
Quote:
I'm gonna listen in here- Taurus started doing the same thing.
"Hillbilly Deluxe"
  #13
Old 01-20-2016, 03:06 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile CowboyBilly9Mile is offline
CowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond repute
Okay kids;
On auto it will put out heat, not a huge amount though; BUT, rarely does it go where I need it. If I hit defrost, it loses heat gradually but puts the air in the correct location.
Bring me up to speed.......somewhere in here, didn't you mention you got a new ride and if so, I assume it's implied that it has EATC? And if yes, does it have a lot of miles?
-Bill
-Life is far too short to be serious all the time. So if you can't stop and laugh at yourself along the way, give me a call and I'll do it for you.
04 Ranger Fx4 Level II, 5R55E, Sonic Blue Pearl, loaded.
Useful Ford Vehicle Resources:
Owners Manuals >>> http://www.fleet.ford.com/partsandse...owner-manuals/
Build Information (click on "vehicle") >>> https://www.etis.ford.com/
Wiring schematics and TSB's (click on "technical information") >>> http://bbbind.com/
Repair guides, includes schematics w/connector pinouts >>> http://www.autozone.com/repairinfo/r...nfoLanding.jsp
  #14
Old 01-20-2016, 07:30 AM
1970Custom's Avatar
They call me Spuds
New ride in the sig, yes EATC, not what I'd consider high miles but a few hundred shy of 181k
Пробковыйy
  #15
Old 01-20-2016, 11:20 AM
Okay kids;
What caught my attention was the item made bold above. The previous rendition of EATC head unit, a single zone head unit, which is *probably* just cosmetically different than the superseeding model (single zone), was known to have a valving issue after lots of use (IMO, 181K would make it a candidate). Internally, there were, I believe, four sliding valves, piston in cyl style, electronically operated, and they have o-rings on them that degrade/fail with use, resulting in vac leakage and thus, issues with the air being directed to where it it desired. The fix for this is $99 on ebay or to troll the net, find the size of o-rings needed, replace them and use a light coat of silicone grease during reassembly. There used to be a youtube vid on how to replace those o-rings; if it's not still there I believe I downloaded it and can email it to you. You may even find someone selling a repair kit with those 0-orings on ebay.
Suggestion, with the above knowledge....a) troll the net a bit and see if this issue applies to your head unit and model b) If you have the vac operated on/off valve in one of your heater hoses, and when it's blowing cool/cold when it should be hot, see if that valve is open, partway open or closed. This, based on a vac leak on those o-rings. Food for thought and something easy to look into.
-Bill
  #16
Old 01-20-2016, 11:50 AM
Sparky83's Avatar
Sparky83 Sparky83 is offline
Virginia Chapter member
theres a difference between vent heat and defrost settings. when its just on "heat" whether it be dash or floor or vents, your A/C pumps not running.. but when you switch to defrost your compressor kicks on.. was something they did to keep your compressor "active" in the winter so it wouldnt be locked up when you went to use it in the summer. If your blend doors are not operating fully the cold from the evaporator when the compressors running on defrost is counteracting the heat coming off the heater core.. also if your heater core is operating less efficient in comparative to the evaporator in addition to the blend doors the air charge would be cooled further than the amount of heat being exchanged in the air flow.
Shawn
2004 3.9L V6 Mustang
-John F. Kennedy
-Christopher Titus
  #17
Old 01-22-2016, 11:24 AM
Here Eric, should it get down to this:
*This is what guys on ebay are getting $100 + shipping to do. IMO, this vid deserves to be put up as a sticky.
-Bill
  #18
Old 01-23-2016, 07:35 PM
1970Custom's Avatar
They call me Spuds
And that's the unit itself or down behind the dash?
Пробковыйy
  #19
Old 01-24-2016, 11:02 AM
That is the valving inside the EATC head unit.
-Bill
