- 35
- 1
I have a 1986 F-150 2wd with a 4.9 automatic c6 transmission, and the feedback carb system. For the past several months I am having rough idle issues when the truck is starting cold, or cooled down. When I put the truck into reverse, or drive for the first time after cold starts, it wants to stall. Then once I move the truck, and get it going, it doesn't do it again until it is cold again. I have replaced many, many things. The only things I have not changed are the components that go to the air pump, smog system. I Changed the transmission fluid and filter about a year ago, and adjusted the band at the same time. I am not sure if it is a transmission problem, or a fuel problem, but the truck does not have a high idle when it is cold, and I cannot get it to idle high. I really need help. I am really stuck, and there are absolutely NO garages in this area that work on older vehicles. Especially the feedback systems. I have a code 41 also which is lean condition.
