i want to convert my 300 cid from the module ignition to an old school points ignition with vacuum advance question here is what do i need and how to connect, my thought is:
ignition coil (1970's 300cid)
distributor (1970's 300cid)
run a vacuum line from my lpg carburator to the vac of the distributor,
12v line to the coil (with a resistance to get +-9V)
12V line from starter solenoid S connection to the coil
a wire to run from the coil to the condenser/contact point inside the distributor (TACH wire)
is that about it or do i need more? and what have i missed for installation?
