Oil pump while I'm at it?
dakonthemountain
California Chapter member
Since I'm going to be replacing the rear main seal and have to drop the oil pan to do it, even though I have no issues with my oil pressure would you recommend replacing the pump while I have the pan out? I know this sounds like a rhetorical question, but $ comes into play here.. so if I do replace it, what do any of you recommend?
Thanks!
Dak
Personally I would. I would also replace the screen as well since you are in there.
Well, normally if youre having oil pressure probs, it isnt the pump, its that the engine is worn. Since yours is doing fine, I'd personally clean up the screen and forget it.
