- Moderator
- #41
Cool vid!
Thank You!Cool vid!
I found the exact 8" booster / master cylinder combo I purchased from the same seller. Here is the ebay link.Great lookin stuff there !...
I need to upgrade my brake booster ,d you have a link where
you got the booster?....
If you have drum / drum, you will not use the combination valve included in this purchase. You will use the existing metering valve bolted on the inside of the frame under the drivers door. This is primarily for Disc / Drum or Disc / Disc. It is a disc / disc master (both resivoirs large) but that just means more fluid capacity.I found the exact 8" booster / master cylinder combo I purchased from the same seller. Here is the ebay link.
http://pages.ebay.com/motors/link/?nav=item.view&id=321975301836&alt=web
Sent from my HTC One_M8 using Tapatalk
