93 E150 Fuel Pump
93 E150 Fuel Pump not working...
Is there a way to check the (Fuel Pump) & (wiring/power)... Before I drop the tank to replace the Pump ?
Did you get your charging problem fixed? It seems like this truck might be a wiring nightmare.
yes the charging problem is fixed... But now the fule pump stop working.. we droped the tank and took out the pump, then tested it going stright to the Battery and it works this way... i need to find out what fuse or relay or wires could cause this to stop working...
