Has anyone tried to adjust valves with engine running?
Feb 16, 2022 #1 keithgonzaleskeithgonzales518 walker, La Has anyone tried to adjust valves with engine running?
Feb 16, 2022 Moderator #2 FellroModeratorStaff member7,953360 Iowa County, Iowa There is no adjusting the lash while running on these motors. You torque the rocker bolts to 18 ft lbs and done. If adjustment is needed, you have to shim the rocker pedestal.
