33 gal bronco gas tank in a f150
A_G
wuh?
3,188
74
Tulsa, Ok
can it be done. and how hard would it be...
1970Custom
They call me Spuds
14,107
447
Middleton, ID
It's doable, need the pump, pickup, and tank IIRC along with the straps...
Lost
PA Chapter leader
3,288
central PA
Not a bad swap . very little fab work to do .
msb71
Virginia Chapter Leader
1,624
28
Hampton,VA
Always a good thing to get the strap and brushgaurd off a Bronco , I did this swap in my truck, everything is great. Just make sure you get a sending unit and pump from the Dealer , cost a little extra , but you will get the right part.
It's a 32 Gallon tank that is in a Bronco.
flareside_thunder
7,812
246
Also I read a tech somewhere where someone did this swap...he had to use a flexible fill hose for a marine application because the fill point is in a different location.....
