Go Back   Ford Truck Fanatics > General Maintenance, Performance, and Tech. Info > Electrical
Old 04-17-2021, 09:50 AM
Sparky83's Avatar
Sparky83 Sparky83 is offline
charging multiple batteries out of vehicle
for you electrical gurus i have a simple (probably stupid question)...
got the batteries outta the truck while im tearing it apart for the head gaskets again.. and wanting to put the float charger back on them while theyre being stored.. im wanting to only use the one float charger like i did while they were connected in the truck but wanted to make sure my idea would work...
what i want to do is get 2 terminals and make a jumper to go between the two like pictured there and then connect the charger the one battery... will it work like ive drawn??? (sorry im not a paint drawing wizard so it looks cheezy... and im worse by hand)... reason im wanting to put the charger on them while theyre outta the vehicle is because i just got those batteries and last time i had a different set out to do the headgaskets they died sitting in the bed...
Shawn
2004 3.9L V6 Mustang
-John F. Kennedy
-Christopher Titus
Old 04-17-2021, 10:16 PM
SuperCab's Avatar
SuperCab SuperCab is offline
Super Moderator
Super Moderator
Yes... should work perfectly the way you've drawn it there. I've done it before just by stripping the ends on two pieces of wire and twisting them around the posts... not pretty but it serves the purpose
-Frank
What's your view on sheep?
Old 04-17-2021, 10:30 PM
Sparky83's Avatar
Thanks Frank... i got 2 sets of terminals to make the jumpers with... i have some 0/2 wire laying around still from the winch install to make the jumper for... so it cost me all of $4 for the terminal ends...
Shawn
-John F. Kennedy
-Christopher Titus
  #4
Old 04-18-2021, 05:12 PM
heavydoc's Avatar
heavydoc heavydoc is offline
Instigator
heavydoc is a splendid one to beholdheavydoc is a splendid one to beholdheavydoc is a splendid one to beholdheavydoc is a splendid one to beholdheavydoc is a splendid one to beholdheavydoc is a splendid one to beholdheavydoc is a splendid one to beholdheavydoc is a splendid one to behold
Yep it will work perfectly like that, hopefully your wires won't be kinked like the drawing, you don't want to prevent electrical flow. It's the same concept as kinking a garden hose.
01 Excursion Limited 4WD
02 F-350 CCLB DRW 4WD
20 Kenworth T270
"DOC"
  #5
Old 04-18-2021, 10:51 PM
Sparky83's Avatar
Got it done today.
Shawn
-John F. Kennedy
-Christopher Titus
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
