Go Back   Ford Truck Fanatics > F-Series > Generations 2-3
Generations 2-3 19531960 F100, F250, F350
  #1
Old 04-11-2007, 02:24 AM
Brian_B Brian_B is offline
blank
Brian_B is a splendid one to beholdBrian_B is a splendid one to beholdBrian_B is a splendid one to beholdBrian_B is a splendid one to beholdBrian_B is a splendid one to beholdBrian_B is a splendid one to beholdBrian_B is a splendid one to beholdBrian_B is a splendid one to behold
9" open to limited slip?
Hello,
This is way, way down the line, but.... (this forum needs something)
I swapped some junk ch**y parts for a ford 9" to go in my 56. I can't go pick it up until the truck is drivable again (catch 22?). I don't know the exact year it came out of. It is supposed to be 3.50 gears (is that even offered in a ford?). I thought ford had a 3.73...but what do I know.
A guy dad works with (I have gotten a lot of parts from him ), tried it under a later truck and it was too narrow. He swapped it out with a later (wider) 9" and put his 4.10 gears in the newer one.
Anyway, it is basically a bolt in because it is from an early F-100. They got wider about 72 (or so).
It is an open carrier. Is there an inexpensive way to change that to a limited slip (or whatever ford calls it)? I looked around the net (places like hotrodders) and could not find the information.
thanks,
Brian
My project journal ..............................................2008 FTF Truck of the year!
  #2
Old 04-11-2007, 05:25 AM
BKW's Avatar
BKW BKW is offline
Ford Parts Guru
BKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant futureBKW has a brilliant future
Quote:
Originally Posted by Brian_B View Post
Hello,
It is an open carrier. Is there an inexpensive way to change that to a limited slip (or whatever ford calls it)? I looked around the net (places like hotrodders) and could not find the information. thanks,Brian
The rear ends widened in 1973, and Ford used to sell a kit (B9AZ-4880-A) to convert to Limited Slip. Whether Ford sells the kit anymore, I dunno...but someone must. The 3.50-1 ratio~(C9OZ-4209-A) is correct.
Bill / Retired Ford Parts Manager / Part Number Research: 1928/2001 FoMoCo vehicles.
2017 Fusion SE
  #3
Old 04-16-2007, 02:48 AM
blank
What is involved in the installation of this "kit"? Is it something that I can do in my driveway with hand tools or does it need too be taken to a shop with special equipment?
I have never been inside a rear end housing.
I assume this is not a spool. I know there are what they call "lunch box lockers" for the 8.8 that can be put in at home fairly easily.
  #4
Old 04-18-2007, 02:16 AM
BKW's Avatar
BKW BKW is offline
Ford Parts Guru
This is a job for a professional, because the rear end has to come apart to install the LS kit, and the lash has to be re-set when it goes together. All the bearings should be replaced while the rear end is apart, as well as the parts needed to reset the lash. Want all the parts numbers? Let me know.
2017 Fusion SE
  #5
Old 04-18-2007, 03:28 AM
blank
No...thats ok. I appreciate the information. It will definately stay open.
Money is too tight (with my medical bils) to pay somone to do anything to this truck. If anything ever gets done...it will be me doing it. Mechanical, body, paint, etc.
  #6
Old 04-18-2007, 07:15 AM
bowtiehatr bowtiehatr is offline
bowtiehatr is a jewel in the roughbowtiehatr is a jewel in the roughbowtiehatr is a jewel in the roughbowtiehatr is a jewel in the rough
bkw, do you know if the kit is still available?
  #7
Old 04-18-2007, 05:50 PM
BKW's Avatar
BKW BKW is offline
Ford Parts Guru
Quote:
Not from Ford, because there haven't been 9 inch rear axles for years...Ford found something cheaper, but in no way as good: the 8.8.
The kit may be available aftermarket, but, sorry dunno.
2017 Fusion SE
  #8
Old 04-18-2007, 08:03 PM
well i am a ford tech so i may be able to track one down. im working on my fsb and havnt torn into the rear yet so i am looking for ls options.
  #9
Old 04-19-2007, 02:02 AM
BKW's Avatar
BKW BKW is offline
Ford Parts Guru
Good luck, they have been obsolete for over 30 years. The last one I sold was prolly in the early 70's. The clutches (4945/4947) are still available. That's about it.
2017 Fusion SE
  #10
Old 04-19-2007, 02:24 AM
blank
Fast parts network (ford parts network), does not list that part number. I looked just to see. LOL
