Go Back   Ford Truck Fanatics > F-Series > Generation 10
Generation 10 1997-2003 F150, F250LD incl. 2004 Heritage
  #1
Old 11-20-2020, 08:42 PM
Larms Larms is offline
Larms is on a distinguished road
BW4406 tear down.
I will attempt to document the rebuild of this unit. I picked up a low mileage used one to install because its my DD. But plan to rebuild this one as a spare. They are not easily obtained in my area.
  #2
Old 11-21-2020, 09:20 PM
Ok new issue. I swapped in the new transfer case. Same part number etc. Prior to this the old one even in such bad condition would engage 4wd. 4x4 light on instrument cluster would light up as well. Now no light. Not certain 4wd high is engaging. 4 low feels like it engages. Would the switch on the transfer case be the sole issue? Or what else should I look for?
  #3
Old 11-22-2020, 08:08 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
Did you meter the switch to see if it was opening/closing? I'm assuming it's just a 2 pin with a plunger or magnetic sensor?
Quote:
Quote:
Quote:
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
