Go Back   Ford Truck Fanatics > Special Interest > Trailers, Towing and RV's
Trailers, Towing and RV's If you can pull it, discuss it here.
  #1
Old 03-21-2020, 08:12 AM
john112deere's Avatar
john112deere john112deere is offline
Super Moderator
john112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond repute
tie-down points
I bought this trailer last fall, and I've used it quite a bit...finally getting to where time and weather will allow me to do some clean-up and improvements to it.
Mostly it's pretty straightforward stuff- sand and paint, fab a better license plate bracket- all the usual things.'
I'll probably put a wood floor in it eventually but not sure that's in the cards this spring.
But one of the most important improvements I want to make is adding better tie-down points. Lashing straps to pipe rails, or stake-pockets sucks. I picked up a 4-pack of d-rings the other day, and I may get some more- can't have enough tie-downs.
Looking for ideas, guidance and wisdom on where to install them...I've used the trailer for furniture, small tractors, motorcycles, and other assorted crap; I expect that is fairly representative, with a focus on the tractors, bikes and assorted crap. (Bolting a couple scraps of 2x4 through the floor to keep the bike tires from sliding side-to-side has worked well; I'd like an easier way to install and remove but I'm not currently planning on adding a proper wheel-chock.
Dimensions are a little unusual- 5.5' wide and 9' long inside...but works pretty well for me. Very easy size to tow, but big enough for what I need to haul.
-Ian
1997 Ranger XLT 4x2, 2.3L 4-cyl 5-speed -- 2009 Ranger XLT 4x4, 4.0L V-6 5-speed -- 1986 BMW R80
The advantages of modern engineering are in many ways over balanced by the disadvantages of modern civilization.
--Col. W.A. Roebling
  #2
Old 03-21-2020, 01:44 PM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
We always install the anchors to the corners and one up front center of the deck.
Click for weather forecast
________________
Randy
  #3
Old 03-21-2020, 04:10 PM
Fellro's Avatar
Fellro Fellro is offline
Admin
Near corrners, middle,front, rear, sides.
My trucks:
  #4
Old 03-21-2020, 11:04 PM
Blue-Truck-Nut97's Avatar
Blue-Truck-Nut97 Blue-Truck-Nut97 is offline
Blue-Truck-Nut97 is a glorious beacon of lightBlue-Truck-Nut97 is a glorious beacon of lightBlue-Truck-Nut97 is a glorious beacon of lightBlue-Truck-Nut97 is a glorious beacon of lightBlue-Truck-Nut97 is a glorious beacon of light
A buddy of mine put a strip of E-trak down the floor of his, one on each side. Worked surprisingly well.
If D rings is your thing then I like the corners, and one ahead and one behind the axle. Then a couple up front, set in from the outside edge a piece.
  #5
Old 03-22-2020, 12:32 AM
SuperCab's Avatar
SuperCab SuperCab is offline
Super Moderator
Super Moderator
Get another pack and weld 4 per side down the bottom angle iron on each side. Should be set then
-Frank
Quote:
What's your view on sheep?
  #6
Old 03-22-2020, 08:15 AM
Super Moderator
Quote:
Any issues with dirt and crap getting into the track? I was looking at that, but it seems like on an open trailer (that's stored outside) it would end up packed with crud over time?
Quote:
Don't have a welder here, so I'll be bolting them. (That said, I have a friend who's a certified welder and has expressed interest in borrowing the trailer when he doesn't need or want to use his big equipment trailer...if he ever does so, I might ask it come back slightly improved from when it left.)
Fortunately it's a small trailer that I pull with a small truck, so the loads aren't that heavy.
-Ian
  #7
Old 03-27-2020, 11:42 AM
On an expanded metal floor, not really. On a wood floor it might pose a problem. For what it is, e track is surprising easy to wash out, if you are going to be hauling gravel or something on it with a wood floor....... probably not a great solution.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
