Heater core replacement
So i am replacing my heater core (no a/c standard output) and noticed that the previous one had cardboard wedged between the heater core and the heater box. Not blocking the fins but on top and bottom to keep it from sitting loosely in there.
So my questions is what is normally used to achieve a snug fit? I would hate to have it rattling around in there. My new one also fits loosely. Should i just use cardboard again?
Thanks
The original was held in with a type of foam tape similar to a weather strip tape found at local hardware stores.
Hmm. I asked about that foam with tape backing at autozone and they said they didnt sell it. Ill see what i can find then.
BKW
Ford Parts Guru
And then Ford replaced the heater core in 1983 with one that had different dimensions than the 1973/79 original.
You also had to buy a mounting kit that consisted of thicker foam rubber so the damn thing would fit properly.
The replacement heater core is available from auto parts stores, but the kit is obsolete from Ford and was never sold by parts stores.
And even though the replacement has a 1983 part number, this heater core was not used after 1979!
