Go Back   Ford Truck Fanatics > Superduties & Other Trucks > Superduty Gen.1
Superduty Gen.1 1999-2007 F250, F350, F450, F550
  #1
Old 05-15-2019, 01:05 PM
michael_maloney michael_maloney is offline
michael_maloney is on a distinguished road
05 6.0 hiccup/stutter
05 F350, bottom line, the engine cuts-out for about a half second, completely randomly. So when at RPMs it's just a stutter, at idle it's a stall. After the cut-out, the injectors rattle, like a fresh start. Which component is the one that actually rattles the injectors?
Replaced the ICP sensor (it tested bad) ICP is good, replaced the cam position sensor. A bunch of other stuff is fresh, less than 10000 miles on HPOP, IPR, injectors. FICM voltages are good 13ish in 46.5 to 48 out. Fuel pressure 60lbs.
Any ideas?
Sent from my Moto Z2 using Tapatalk
