Go Back   Ford Truck Fanatics > General Maintenance, Performance, and Tech. Info > General Automotive
General Automotive Technical Catch-All
  #1
Old 02-12-2019, 02:37 AM
bradleyheathhays bradleyheathhays is offline
bradleyheathhays is on a distinguished road
Need to rethread a plug hole from a blown plug
Bought an '11 Vic with the 4.6L back in June and a few months back I tried to change out the plugs. All came out ok except for cyl 4 which only cranked out 1/4 turn. Had a shop take it out and they said they had to redo the threads. I've seen videos where you can remove a stuck plug by drilling into it somehow, but because this was in the 4 position and hard to get to I'm guessing they just power cranked it out. Not sure but I'm guessing those threads are compromised now.
Well, this past weekend that same plug blew out of cyl 4. Inspection reveals a coil and boot jammed up underneath the fuel rail and a plug that I fished out without any turning. When I go to install a new plug it just sits on top of the threads and turns without going in. So I guess what's happened is that the plug rotated most of the way out but when it got to the last couple threads the compression blew it out the rest of the way, and that it's just the top few threads in the hole that are damaged. Inspection of the plug reveals that most of the threads are intact except for the 2-3 that are closest to the element.
So my question is...should I try to fix this myself or just take it to a shop? Some kind of tap tool would probably fix it, but since it's the beginning threads that are boogered it'd probably have to start from the inside of the cylinder. I really don't have a clue as to how to approach this.
  #2
Old 02-12-2019, 07:41 PM
heavydoc's Avatar
heavydoc heavydoc is offline
heavydoc has a spectacular aura aboutheavydoc has a spectacular aura aboutheavydoc has a spectacular aura about
I had a 97 F150 eith the 4.6 and bought a rethreader grom one of the tool trucks I ran into, I think it was matco. But I believe there are inserts you can buy now for this repair. It's no more difficult than running a heli coil in.
Sent from my SM-N920V using Tapatalk
