Go Back   Ford Truck Fanatics > Engines > 289, 302, 351W
  #1
Old 01-12-2019, 01:03 PM
ainteasybeinsteezy ainteasybeinsteezy is offline
ainteasybeinsteezy is on a distinguished road
Belt/pulley alignment issue '91 5.8
I had my timing chain and water pump replaced and I got maybe 1000 miles down the road and my belt shredded.
I put a new belt on and noticed that its walking up the edge of the crank pulley.
I tried replacing the tensioner/tensioner pulley but it didn't help. I think the crank pullley somehow got put back on wrong?
Anybody know how I can adjust the alignment or if its even adjustable?
Sent from my SAMSUNG-SM-G930A using Tapatalk
  #2
Old 01-12-2019, 01:21 PM
fatherdoug's Avatar
Looks like the crank pulley wasn't sucked in far enough?
'78 F-150 Lariat
Quote:
Quote:
  #3
Old 01-12-2019, 01:30 PM
Fellro's Avatar
Fellro Fellro is offline
Admin
Unless you sleeved the balancer, it does appear to be farther out than it was before. The clean area on the seal area looksto be a ways out from the seal.Also seems like the pulley alignment is off. However, the way the belt runs seems you are too far in.
My trucks:
  #4
Old 01-12-2019, 01:31 PM
Like the harmonic balancer wasn't fully pressed on?
Can I fix this without pulling the radiator? I JUST finished messing with it and my trans cooler line fittings are about stripped and are a real booger to work o. :-/
  #5
Old 01-12-2019, 01:35 PM
Quote:
Can you over press a balancer though? I thought you were supposed to bottom it out. I didn't sleeve the balancer but I have no idea what the previous owner or the shoddy mechanic may have done to it. (only guy around that could fit my clubwagon on his lift)
  #6
Old 01-13-2019, 11:11 PM
Fellro's Avatar
Admin
Can't over press, only under press. It was only an observation based on pics, which unfortunately aren't always as good as seeing it personally.
My trucks:
