  #1
Old 07-29-2018, 06:56 PM
dexleo2 dexleo2 is offline
dexleo2 will become famous soon enough
1977 Ford build thread
Hello everyone,
I have been on this website for awhile now and I just asked a couple question and couple time looking for information, well I decide I would share with you my project I have been tinkering with for awhile now. I have just completed a front end overhaul with new bearings, u-joints and ball joints. Then I have completed a 4 inch lift. see the pic below I have a before and after. Next up I'm waiting for shocks and steering box and other components. Before nolift.jpg
After:
will update once I get all my parts this weekend. Thank you
  #2
Old 07-30-2018, 10:49 PM
Fellro's Avatar
Fellro Fellro is offline
Admin
Looks like a reasonably solid truck, hope it goes as planned for you.
My trucks:
  #3
Old 08-07-2018, 09:45 PM
Jasperrc's Avatar
Jasperrc Jasperrc is offline
Texas Chapter member
Jasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to beholdJasperrc is a splendid one to behold
I like the lift, looks great!
What's next?
- Russell
'77 F100 Flareside
  #4
Old 08-09-2018, 09:32 PM
well I just received the shocks and I need to get them on soon.. next up I need to run it around the section here a couple times and see how it drives since I have never really had it on the road. I need to see if there is a bunch of slop in the steering box to determine if I should replace it... On my 71 Mach 1 I had a lot of slop in the box and it was very hard to drive at 60 mph and I would just assume see if this one needs replaced or not before I start driving it to work and such... SO that is where I am with it.. I know boring but this will be a slow build. Thank you everyone
  #5
Old 08-13-2018, 06:10 PM
Jasperrc's Avatar
Things are always slower when the vehicle is in use .
We've been working on ours for 7 year and it's still got a LONG way to go , lol
- Russell
'77 F100 Flareside
  #6
Old 09-03-2018, 05:44 PM
Well today I tore into the heater box and all. So I could replace the heater core and blower motor to make sure everything is up to the challenge of the great Midwest winters. Well has anyone seen this type of factory installed AC before.
  #7
Old 09-03-2018, 08:16 PM
Jasperrc's Avatar
I've never seen a factory install like that. Could it be a dealer add on rather than factory?
- Russell
'77 F100 Flareside
  #8
Old 09-03-2018, 08:17 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
I believe that was a factory piece that was dealer installed.
Quote:
Quote:
Quote:
  #9
Old 09-04-2018, 06:14 AM
Fellro's Avatar
Admin
Is the evaporator box under the dash, or out on the firewall? Under the dash was dealer installed, out under the hood on the firewall was factory installed typically.
My trucks:
  #10
Old 09-06-2018, 10:06 PM
Quote:
yep it was under the dash in front of the regular heater box. I had to take the side of the dash lose to get it out so I could get the heater core and regular heater housing out. I guess I found it interesting that it was a dealer add on. Now I have two more holes in the firewall I have to weld up when I get to that point... LOL...
Well tonight I got the power steering pump overhauled, along with a new heater core and blow motor installed. I will get them back into the truck hopefully tomorrow and maybe Saturday I will get the steering gear box replace. Will get pictures tomorrow..
